    NprTools
    extensions
    83 Posts 9 Posters 18.7k Views 9 Watching
    • Al HartA Offline
      Al Hart
      @richcat said:
      Al
      It seems to be conflicting with Rptools, I'll try and see if it makes any difference by removing Rptools.
      Yes, We really need to put out a new version of RpTools as well to match it.
      [Edit] You can't really remove RpTools. It shares the same code space, and installation folder as NprTools.
      (They are the same internally, except for the toolbar)
      If you have a valid license for RpTools, or the Combo Pack, use that license and request an authcode for NprTools. People who own either of these products to not have to purchase NprTools. It will be included.
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
      • Al HartA Offline
        Al Hart
        Note to self: Don't release a new Beta Test product just 30 minutes prior to when you will be gone for several hours.
        If anyone has problems, be patient and look again tomorrow.
        Al Hart
          richcat
          I was able to quickly try out soft shadows but even though I selected launch when complete, had to go searching for the image produced in "My Documents\NprTools\SoftShadows"
            richcat
            AL
            On the machine I'm testing this on it has an a copy of RpTools but the trial has expired, which basically leaves me with the tools in RpEdits.
            My laptop has the fully functional copy of RpTools, but I have not tried Nrptools on this yet.
            Just luv these soft shadows (10 iterations & time increment set 1) 🎉
              BTM
              Sorry I haven't been able to scan the sketchy lines %(#808080)[(still 😞 )]. i've had issues with a few things, including finding out which surface I drew the cleaner-looking diagonal lines on ( I've tried a few different places...).
              Oh, and on the NprTools wiki, it says 'diagonals not available' for the thin lines, but I did post them 😕
              http://www.sketchucation.com/forums/scf/download/file.php?id=26739
              http://www.sketchucation.com/forums/scf/download/file.php?id=26740
              lastly, I can't use it because i don't have a sketchup enabled windows computer lying around. Still, I can't find the demo download link on the downloads page 😐 If it's there, I guess I'm not looking hard enough 😆
              ...Also, anyone have any sketchy shadow examples? 😄 I just want to see how they work.
              • Al HartA Offline
                Al Hart
                We did start on the Mac version last week, but it will be a little while before it is ready.
                Al Hart
                • Al HartA Offline
                  Al Hart
                  @richcat said:
                  Al
                  NprTools is checking the trial days for RpTools instead of the new trial days for NprTools.
                  There is no easy fix.
                  I'll post a new version tomorrow for people who already have RpTools installed.
                  Sorry,
                  Al
                  Al Hart
                  • Al HartA Offline
                    Al Hart
                    I just added the NprTools checkbox to the download form.
                    (You can download all products even if you don't check them off)
                    And it is on the page you get after filling out the form.
                    In either case, click Refresh if you can't see it.
                    Al Hart
                    • Al HartA Offline
                      Al Hart
                      @richcat said:
                      Al
                      People with RpTools installed may be having a problem with NprTools.
                      (Uninstalling RpTools doesn't help)
                      We will post a new version on Wednesday.
                      Al Hart
                      • Al HartA Offline
                        Al Hart
                        I had a similar problem launching images on my Vista machine, but I thought I had it fixed.
                        See This Thread
                        Try a couple of things for me.
                        1. In the Ruby console, store the full path of a png image in a variable s1, using
                        s1 = 'c:/path.../image.png', or
                        s1 = 'c:\path...\image.png' (with single quote marks, you do not have to escape the back slashes)
                        Then type in: UI.openURL(s1)
                        This should launch the image.
                        s1 = 'C;\docs\NprTools\SoftShadows\Shadows-k.png'
                        UI.openURL(s1)
                        true
                        (every other response here is the outut from Ruby.)
                        Also see what is returned by UI.openURL (true means that it thinks it worked)
                        1. If it doesn't launch the image, then navigate to the .PNG file in Windows Explorer, and right click on it. See what verbs are displayed and what the default verb is.
                        If Open is in this list, and if the default verb (in my case Edit), launches the image then it should work.
                        1. If UI.openURL does launch the image, then type in:
                        $nprtools.launch_file(s1)
                        and see what happens.
                        Al Hart
                          richcat
                          Al I'm on XP Pro
                          Tried the ruby code above and it opened with both versions followed by UI.openURL(s1)and $nprtools.launch_file(s1)also worked.
                          If I double left click image it opens in image viewer, If I right click I get the menu as below.
                          • Al HartA Offline
                            Al Hart
                            @richcat said:
                            Al I'm on XP Pro
                            Thanks for the help richcat.
                            Hopefully NprTools will launch the images properly for you when you get the new version.
                            Al Hart
                            • Al HartA Offline
                              Al Hart
                              SOn the NprTools wiki, it says 'diagonals not available' for the thin lines, but I did post them 😕
                              Thanks,
                              I added the diagonal patterns to todays release.
                              (It will go our as soon as Rich gets back from feeding himself)
                              Here is a Sketchy Shadow example with the diagonal thin lines.
                              (I rotated the house a little so we wouldn't have to see the same old boring model again. 😞 )
                              Al Hart
                              • Al HartA Offline
                                Al Hart
                                We put out a new version - ID13npr - which fixes the problems with RpTools preventing the trial version and adds the two missing thin line textures for Sketchy Shadows.
                                Al Hart
                                • Al HartA Offline
                                  Al Hart
                                  Al Hart
                                    richcat
                                    Thanks Al that did the trick with the trial period.
                                    • Al HartA Offline
                                      Al Hart
                                      Great - when you get a chance to test "Sketchy Shadows", post an image (like your bench) for others to see.
                                      Others - If you have some images or comments to share please post them here.
                                      For example, people have liked the idea of color shadows - but every time I try them they look awful.
                                      Another tip - I used the SketchUp Vegetation material for Sketchy Shadows (Sketchy Shadows ignores the color of the pattern) it worked great. Try a few things like this and let us know what you get.
                                      Al Hart
                                      • PixeroP Offline
                                        Pixero
                                        Any chance to get colored soft shadow without sketchy lines?
                                        • Al HartA Offline
                                          Al Hart
                                          I installed NprTools but it's not showing under the Plugins menu, I tried a restart with no improvement. do i have to remove irender nxt first?
                                          Make sure NprTools_loader.rb is in your SketchUp/Plugins folder. If not then the install did not work properly.
                                          If it is there, start the SketchUp Ruby console (Windows/Ruby Console), and enter:
                                          load 'NprTools.rb'
                                          and send me the results.
                                          Al Hart
                                          • Al HartA Offline
                                            Al Hart
                                            Yes - make a "textured" material in SketchUp, where the texture is actually a solid black color.
                                            Select the new Material in SketchUp and use the first radio button - "Current Material"
                                            Al Hart
                                            • 2 / 5
