    Creating a half dome?
    8 Posts 3 Posters 1.2k Views 3 Watching
      Tekkybot
      how do you do it πŸ˜„
        Make a full dome and cut it into half. πŸ˜‰
        Now seriously. If you only lathe a shape around a half circle, you will end up with unwanted and weird geometry on both "sides" of your half dome. Therefore this workaround. You can make a dome, can't you? If not, some of the steps (4-7) of this tutorial are about that. I'd suggest however reading the whole tutorial as this is the best tutorial so far at SketchUcation.
        πŸ˜„
          Tekkybot
          thanx for that. i just had alot of success using the shapes plugin. i added the dome, edited the group, and er cut the dome in half easy as pie 😳
            πŸ‘
              That was my initial thought when I read the topic title. πŸ˜„
                But there IS indeed the reason - it's just a right place to shoot a joke with it.
                  Tekkybot
                  yeah but i just realized that i have to turn on hidden geometry to cut the dome or else it cuts into squares 😳
                    Hidden geometry will soon (and often) be your friend. I even have a shortcut for it.
