    Matching SUp focal length to photo
    8 Posts 5 Posters 1.1k Views 5 Watching
    • P Offline
      pgarch
      Hi, I am doing some photomontages of a building in the landscape without any reference for SUp's photomatch.
      The photo has a 35mm equivalent focal length of 17mm, I had hoped that I could set the focal length on SUp to 17mm and the focal lengths would match, they do not, Is there a way to match the focal lengths?
      I tried matching the field of view and that does not seem to work either.
      Thanks in advance Philip
        l.frisken
        well you could try and correct the photo using another program
        • P Offline
          pgarch
          There is nothing wrong with the photo, its just wide angle, not sure why it needs corrected
            FYI: SU uses vertical FOV instead of horizontal.
            • P Offline
              pgarch
              I managed to find a work around, I positioned the camera in Sup in the position the picture was taken and saved that view as it was the correct view only much smaller, I then imported the image into Photoshop and scaled it to the correct size and it seemed to work fine.
              • AnssiA Offline
                Anssi
                Thomthom is almost right. The SU field of view numbers refer to the vertical angle of the lens, whereas in film cameras the angle is usually measured diagonally.
                In digital cameras the manufacturers often quote focal lengths either as the real ones or then as "equivalents" compared to the FOV of 35mm film lenses. A 17 mm lens in a digital camera has a smaller FOV than in a film camera, because usually the digital camera sensor is smaller than a 24 x 36 mm frame in a 35 mm camera. It is complicated more by the fact that many digital cameras can take pictures in several aspect ratios, where a 2:3 ratio is in practice not perhaps the most common.
                Anssi
                • PixeroP Offline
                  Pixero
                  Anssi
                  Thomthom, I think we need a plugin to take care of this. πŸ˜‰
                    It's in the plans to make a Camera plugin. Object representing the Scene tabs (selectable off course) with extra tools and dialogs to visually control them. But I need help to understand how cameras work when I begin on this.
