    Floating Dynamic Components
    6 Posts 5 Posters 1.9k Views 5 Watching
    • K Offline
      kevinmarkb
      I am trying to make a dynamic component that is scalable in repeatable segments in the X axis, but
      that follows the contour of a terrain imported from Google Earth. Is it possible to make a component
      scale in a certain direction while maintaining a specific floatation above a fluctuating terrain??
      Essentially like a fence that hovers X amount of inches above the terrain surface as you scale it in the X axis.
      Any help would be greatly appreciated, I am new to the dynamic component game.
      Thanks!!!!
      Kevin
      aptuskevin@gmail.com
      • boofredlayB Offline
        boofredlay
        Kevin, I moved this to the Dynamic Components Sub Forum. I am sure it will get more traffic here.
        And welcome!
        • Chris FullmerC Offline
          Hi Kevin, unfortunately, that is not something that a Dynamic Component could do. DC's can't really change their behavior based on outside conditions. So a DC could not check the elevation below it and alter its elevation in response.
          Is this a general question, or do you have a specific component that you wanted to get to work like this?
          Chris
          All my Plugins I've written
            I could imagine a DC "stretching" in a certain direction then you could explode it and use drop.rb to get all the nested pieces onto the ground. Would that be "enough"? Note that it couldn't be modified afterwards so this is a final (and non reversible, destructive) way.
            • K Offline
              kevinmarkb
              Hi Chris,
              Thanks for the info. I do have a specific component I am trying to use, namely a ground-mounted
              photovoltaic system for designing large arrays over specific terrain. We have a system that avoids having to grade the site and follows the natural terrain. The terrain from Google Earth is only for rough preliminary sketches. I'll be downloading CAD files with accurate topo info further along. We normally do this the hard way with CAD, RayTrace, etc. I'd much prefer to make mock-ups in SketchUp to map things out. For now I suppose I'll just keep things flat.
              Thanks for the feedback!
              Kevin Bassalleck
              Consolidated Solar Tech.
              Albuquerque, NM
                matthew.robert
                I think in this situation the drop.rb plugin could be used in a non destructive way. Instead of exploding the DC, it could just be edited by double-clicking on it. I threw together a test file and screen capture. Kevin, I would be curious if this would be a reasonable solution.
                Scale the DC in the attached skp, then edit it, then apply the drop.rb plugin (also attached just in case you don't have it).
                Sorry, forgot to record mouse cursor in screen capture.
                [flash=720,405:10e8y6vn]http://www.youtube.com/v/cUAcXObu2mQ&fmt=22&hl=en&fs=1[/flash:10e8y6vn]
                *edit
                I should add that this only really works as long as the z attribute is not formula derived (black)
                Regards,
                Matt Chambers
                concept3D
                solartest.skp
                drop.rb
