    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.5m Views 329 Watching
    • Chris FullmerC
      Hmm, that is interesting. I will try to play with it and see if I can repeat the results. I can't think of any good reason it would do that. But that doesn't mean its not doing it. So I'll see what I can find,
      Chris
      All my Plugins I've written
      • Chris FullmerC
        My first guess would be to try component spray. Just unload that script and see if that does the trick. There was a problem with it and Didier uploaded a new version that fixes the problem. So remove it and that fixes the problem, download the newest update here
        404 Not Found
        (www.sketchucation.com)
        I really think that's it. Let me know if its not,
        Chris
        • E
          edmund
          This plugin is great. I had all of the profiles of my fins drawn already from a physical model I had to build. So this plugin was exactly what I was looking for. Thanks a ton.
          • Chris FullmerC
            Wow! Thats awesome! I'm surprised, I mean glad, that my script worked for you πŸ˜„
            Chris
            • ToboboT
              Tobobo
              Chris,
              Thanks for all your help that worked.
              Also this script is awesome (Sorry) AWESOME!!!!!!!!!!!!!
              And it does railings
              Toby
              Philippians 4:13
              • Chris FullmerC
                Yes, I am well aware of that little detail πŸ˜„ I would like to fix it, it just will take some time and thinking. It is only on the end segemnts that those lines do not actually align correctly. In time, I'll fix it.
                Chris
                  Suggestion πŸ˜„
                  So resize all external segments = ED! πŸ˜‰
                    So maybe make an another external "arc half circle" πŸ˜‰
                    • S
                      Sir
                      i get around the problem by making the curve more curvey thani need it, then intersect a plane through so its cutoff after 180 degrees rotation... its a work around, but it works!
                      • A
                        Alsatic
                        You can also start with a circle and explode it. Then keep one additional segment on each end of the half circle and weld it. You will get something like in the picture. Then erase the two red blocs you don't need and you're done.
                        This solution has been posted on a french forum here:
                        http://www.systemed.fr/Forum/forum_posts.asp?TID=32570&PN=1&TPN=1
                        • P
                          Physicsguy1
                          It won't bend the shapes. The progress bar will completely freeze well below 20%, and won't unfreeze. i don't know what happened.
                            Cool trick & works fine!
                            the funny thing is that the red blocks are false in the length! πŸ˜‰
                            circle explosed and arc curves were build with same length of their segments!
                            • ToboboT
                              Tobobo
                              Try to follow what chris told me to solve my problem with the bar freezing.
                              404 Not Found
                              Chris
                              Toby
                              Philippians 4:13
                              • Chris FullmerC
                                I agree, update component spray. If thats not it, we'll start debugging!
                                Chris
                                • C
                                  caramel1982
                                  The sketches that you have made are just simply amazing. I can't do it myself. I need more practice.
                                  Simulation pret immobilier
                                  -- caramel --
                                  • B
                                    bianhai
                                    Nice plugin, πŸ‘ Thanks!
                                    • D
                                      darkPhysics
                                      Please help me! It just wont work. I have the progressbar.rb, but it wont show the preview of bend. Here is the image
                                      http://img188.imageshack.us/img188/9918/problemfyj.png
                                      . Can anyone help me? Here is my plugins folder:
                                      http://img188.imageshack.us/img188/3189/pluginsfolder.png
                                      • Chris FullmerC
                                        The problem is with the compspray.rb
                                        Update it from here:
                                        http://forums.sketchucation.com/viewtopic.php?f=180&t=11746
                                        Didier had a bug in it that was breaking the progressbar, but he fixed it nicely. So just update that, then it should work.
                                        Let me know if that does not help.
                                        Chris
                                        • D
                                          darkPhysics
                                          Chris
                                          It didn't work with new compspray, but I removed it and it worked!
                                          • Chris FullmerC
                                            I see you are on Vista.
                                            There is a good chance that when you tried to install compospray, Vista played a dirty trick on you. It has a hidden file system called "Compatibility Files" where it puts things without telling you. So try this.
                                            • Delete the existing compospray.
                                            • In the Plugins folder, towards the top is a button called "Compatibility Files" (or maybe Folders). - Click it.
                                            • Now your in a new folder, probably with other scripts. Cut and paste them all back into your regular plugins folder manually.
                                            • If there is a compospray in there, delete it too.
                                            • Now reinstall compospray, and be forewarned that it might end up in compatibility files world, so go track it down, and cut and paste it back into the plugins folder.
                                            • now start SU again, see if shape bender works and if compo spray is installed and working.
                                            I know its lame and a bit of work. Vista just does it to keep us safe 🀒 πŸ‘Ž πŸ‘Ώ
                                            Hope that helps,
                                            Chris
