    [REQ] Macro / Action Recorder
    4 Posts 3 Posters 1.4k Views 3 Watching
    • bagateloB
      bagatelo
      A thing that I like in Modo, in Photoshop, in Illustrator, in Microsoft Word, in Microsoft Excell, VUE xStream, is the possibility to record and to execute macros or actions. Would something like that be possible in Sketchup?
      • J
        Jim
        Isn't this independent of a particular application? I mean, isn't there a "universal" macro recorder that works for any piece of software?
        • bagateloB
          bagatelo
          Maybe you should dream a little about the possibilities. We could record a macro of our action as resizing an object, or starting from one plane, the program to accomplish a series of operations as offset, extrude, delete faces etc, generating a window with same particularities, but with appropriate dimensions for any dimension.
          • jeff hammondJ
            jeff hammond
            there's a recent topic that's along these lines..
            404 Not Found
            (www.sketchucation.com)
            not about a macro recorder rather a GUI for making scripts.
            @jim
            here's a universal recorder and sketchup.. you'll see that i had to lock the orientation of the 2nd circle and that's where things went haywire. [everything after the still shot of the ring is being done automatically]
            [flash=500,405:3dd0x04h]http://www.youtube.com/v/W-4FxpqeKmg&hl=en&fs=1&rel=0&color1=0x2b405b&color2=0x6b8ab6&border=1[/flash:3dd0x04h]
            dotdotdot
