    [req] soften/divide geometry (by angle)
    29 Posts 7 Posters 4.9k Views 7 Watching
    • jeff hammondJ Offline
      jeff hammond
      @xrok1 said:
      hey thats pretty sweet too, what is it? round edge by bezier?
      nah, that ruby can't handle the weird intersection.. here's what it looks like in this circumstance..
      http://homepage.mac.com/jeffhammond/.Public/scf/bezierroundedge.jpg
      i wish the youtube video was clearer so you could see the drop down πŸ˜„
      http://homepage.mac.com/jeffhammond/.Public/scf/mock_blend.jpg
      but no.. no such ruby.. i just used a little movie magic.. there's really a hidden group which had a dose of subdivide/smooth.. i made the selection then acted like i clicked on a ruby but really, i unhid the group..
      i'll attach the skp.. the idea is to keep most of the object flat but certain places could be subdivided.. pretty much what this thread is about but being used in a different circumstance.. (open it and go shift/command/E -- or however you unhide things on windows)
      awesome_rb.skp
      dotdotdot
      • X Offline
        xrok1
        that would be a subd@90deg. πŸ˜›
        hears a thread where we're discussing what you did http://www.sketchucation.com/forums/scf/viewtopic.php?f=15&t=18073
        β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
          archmolding
          just in case this isn't common knowledge already, the way to get the edges to do that with subdivide and smooth is to have offset lines from the edges (not via the SU offset tool though -- the lines need to run edge to edge)
          [flash=500,405:3f3optb9]http://www.youtube-nocookie.com/v/jPRb7QhzvYs&hl=en&fs=1&rel=0&color1=0x2b405b&color2=0x6b8ab6&border=1[/flash:3f3optb9]
          anyone know of a better way?
          Jeff, I wanted to ask you how you took that line and placed it on the other side of the surface in the same spot as the other side. (in your video) Ive been using the tape measure tool all this time to measure in equally on both sides then moving a copy to the other side. How did you do that with out measuring with the tape tool?
          could you email me?
          arch_molding@sbcglobal.net
          Thank you
          -Jesse
          http://www.archmolding.net
          • X Offline
            xrok1
            i imagine jeff knew the dimensions of his rectangle and just typed in the measurement to get it where he wanted.
              archmolding
              Oh yeah I guess if he already knew the width he just did the math in his head, and typed it in...makes sense..Just when i thought there was some new trick... πŸ˜„
                jeff hammond
                yeah, i just mathed it..
                i can't remember the exact dimensions here but probably something like a 6' square.. copy/moved the first line in 6" then moved it another five feet .. i'm a fan of the value control box πŸ˜„
                dotdotdot
                  archmolding
                  thank you Jeff. Awesome forum. Ive got lots to learn here. πŸ‘
                    jeff hammond
                    here are two other ways you could do it which will be quicker than the tape measure.
                    [i tried to make sure to use the toolbar so you'd know which tools i was using.. it would be a lot faster with shortcuts]
                    the first one shows a square and rotate/copy
                    the second one is a rectangle with offset/line inferencing (ie- i was holding the shift key while on the outer perimeter which allows me to get a perpendicular lock)
                    [flash=640,400:2317m0jm]http://www.youtube.com/v/GEJsgVd0zyE&hl=en&fs=1&rel=0&color1=0x006699&color2=0x54abd6&border=1[/flash:2317m0jm]
                    dotdotdot
                      Another variant [if the rectangle's face material is not critical] is Jeff's last one using offset to make the inner rectangle then draw a rectangle from the outer rectangle's corner to the inner rectangle's nearest corner. Repeat that another three times... OR double click it to select its face and 4 edges, copy what's selected to the clipboard (ctrl+C) and paste it [one corner will automatically become the handle], now simply paste (ctrl+V) three copies into place - one copy will have a vertex you can snap to, the others need you to hover over a vertex and use shift/inference to snap as needed. [both ways ~12 clicks as before]
                      Another variant is to draw one corner square, copy/paste it into the other corners as above, then draw another rectangle between these four square's inner free vertices... [~11 clicks !]
                      There are many ways to do this - shortcuts make things MUCH faster...
                      • 2 / 2
