    FPS Rig
    10 Posts 5 Posters 1.3k Views 5 Watching
    • W Offline
      Wacov
      Pretty glitchy... I experimented with more wheels for rotation control but thrusters work better. This is just a test level, If anyone finds a way to make the movement more stable please post it. Anyway, controls are:
      left stick/wasd = forwards/backwards, strafe
      right stick/arrowkeys = turn, look up/down
      right trigger (RB)/space = fire
      FPS rig.skp
      • H Offline
        hobbnob
        I also made one i while back it is an attachment to this post and it has the same controls i think, apart from fire which is only the trigger
        a small fps rig with a gpmg
        My WIP Thread:Here
        • W Offline
          Wacov
          Nice; it works very differently to mine. I really want a gyro that won't rotate, to do the turning from... the thrusters just don't allow precise aim.
          • W Offline
            Wacov
            I figured out how to make a no-rotate gyro! You use two... only downside is that you have to start rotated to 45 degrees pointing down; this immediately chages though.
            Updated
              BTM
              no, you don't have to. this helicopter uses 2 gyros to keep part of the flying mechanism in it's orientation:
              http://sketchup.google.com:80/3dwarehouse/download?mid=38c8f97db4b2bc46b03981761b424736&rtyp=s7&fn=helicoptor+weapon+test&ctyp=sm&ts=1236727405000
                CPhillips
                Very cool!
                I think something might be messed up with Gyros in 3.0. I seem to remember them being better behaved in 2.0.
                  BTM
                  My own shooter: not first person though, the helicopter again. I've been playing around with breakable joints and emitters a bit.
                  WS-thrust
                  AD-turn
                  ←→-roll
                  ↑↓-tilt
                  space-shoot
                  RF-gun angle
                  • W Offline
                    Wacov
                    Ah ok thanks; yours works only when they are that way round. When I tried to counter the spin on mine, it disappeared whenever it touched something...
                      CPhillips
                      It seems that gyros are to some degree broken in SP3. I tried them out in SP2 and they are much better behaved.
                      I figure out what changed....
                        Sgt.A.Johnson
                        I might try and do an fps rig. it will probably end up keyboard control cos i don't have a gamepad though. I thought of a way of making one sprint though with a variation of the scripted transmission jake on the warehouse made.
