    [code] ComponentDefinition-delete
    9 Posts 5 Posters 2.7k Views 5 Watching
      This script adds a new method for a ComponentDefinition...
      component_definition.delete
      It mimics deleting a component-definition from the component-browser.
      All instances of the component-definition are erased (including any locked ones)
      and the component-definition itself is then purged.
      However, any other 'unused' component-definitions remain unaffected...
      unlike "definitions.purge_all", which purges everything that's unused...
      [EDIT: AlexM has written a better version - recommend you get it here - http://www.sketchucation.com/forums/scf/viewtopic.php?p=145255#p145255]
      I have removed my 'code' 20090402...
      • broomstickB Offline
        broomstick
        This is a very handy time saver πŸ˜„
        Thanks 😎
        • Chris FullmerC Offline
          Yeah, thats great. Thanks TIG!
          Chris
          All my Plugins I've written
            I wonder what the performance impact is if there's many unused components in a model. Where I work I've seen models which has been worked on for years without every being purged... But until we get a native function this is the only way I can imagine it working.
            Thanks for looking into this TIG.
              Personally I purge like every five minutes. Hooked up to a hotkey. But I'm a bit afraid to just purge stuff from other people's model when I write my plugins. But your method is a fine workaround in any case. I expect that's what I'll be using.
              • W Offline
                wolfy
                Thanks Tig! Will come in usefull when rendering with Vray since getting rid of any component instances should make render times quicker (after a file copy of course).
                  You could also use my Purge.rb that purges all Components, Layers, Materials and Styles in one go... Then your model would be 'trim'... Later on a few unused things won't give much of an overhead...
                  I've tried "definition.delete" with 30+ unused definitions and it took 'no time at all'...
                    A better version has been written by AlexM http://www.sketchucation.com/forums/scf/viewtopic.php?p=145255#p145255
                    I recommend you change to that and I have added a note to the initial page on this thread...
                      AlexM has found the basis of doing this without a new method at all...
                      model.start_operation("Delete Definition")
                        definition.entities.erase_entities(definition.entities.to_a)
                      model.commit_operation
                      I'm removing my 'code' and rewriting ComponentInstance-add_entites.rb to suit...
