[Plugin Library] LibFredo6
V2020 Win10 - the newest LibFredo was just installed and now all of the Fredo extensions show up with French text, not the usual English !?
The Tools > Fredo Tools > Traduction [aka Translation] is set to EN, but FR is showing...V2019 took the new LibFredo and left everything in EN ? most odd...
But I don't see FR as an alternative language listed in v2019's Translation dialog...EN is the 'preferred' language is both versions...
I thought there was a common set of 'defaults' across SketchUp versions ?
PS:
I fixed it by setting the 2nd/3rd language preferences to 'none' so only EN is set up.
For some reason when the first language is EN and FR is the second FR prevails !
This happens in v2020 & v2019 !
Having just EN set up it works as before... -
@iaincsthorp said:
Hello - Downloaded and installed over earlier version. Restarted Sketchup and MacBook Pro. This is what I get. Any suggestions? I've been using Fredo Corner for several years now. Never had any problem.
MacBook Pro (15-inch, 2018)
OS X Catalina 10.15.4Did you restart Sketchup after installation?
Do you still have the problem?
The Tools > Fredo Tools > Traduction [aka Translation] is set to EN, but FR is showing...That's not new actually. Always been like this...
Default language (i.e. 'none') happens to be my English, whereas EN states for real English, for which I don't provide a translation (and would happily let an English contributor provides a good translation).
If you specify EN + FR, then you'll get mostly French, because LibFredo6 looks at language in order and find nothing for EN and something for French.
I'll do something to avoid confusion.
I didn't specify any language.
In v2019 it lists EN, but in v2020 it auto lists EN/FR/ES [or DE if I don't recall right !] -
NEW RELEASE: LibFredo6 v11.1a - 26 Aug 20
LibFredo6 11.1a fixes an issue where a unsigned 'shadow' extension top_libFredo6 appears in the Extension Manager.
Requirements: SU2017 and above
See plugin home page of LibFredo6 for Download of LibFredo6.
Main Post of the LibFredo6 thread
Fredo
OS X Catalina 10.15.4[/quote]Did you restart Sketchup after installation? A: Yes
Do you still have the problem?[/quote] A: Yes
Here's today's error message
Error Loading File Fredo6_!LibFredo6.rb
Error: #<LoadError: dlopen(/var/folders/6_/9kz2gk_x7b70xbzsq4ghcpt00000gn/T/com.sketchup.SketchUp.2019.johnthorp/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle, 9): Library not loaded: @executable_path/../Frameworks/Ruby.framework/Versions/2.5.5/Ruby
Referenced from: /var/folders/6_/9kz2gk_x7b70xbzsq4ghcpt00000gn/T/com.sketchup.SketchUp.2019.johnthorp/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle
Reason: image not found - /var/folders/6_/9kz2gk_x7b70xbzsq4ghcpt00000gn/T/com.sketchup.SketchUp.2019.johnthorp/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle>
/Applications/SketchUp 2019/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:inrequire' /Applications/SketchUp 2019/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:inrequire'
/users/johnthorp/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:610:inload_binary' /users/johnthorp/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:250:instartup'
/Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:inprocess' /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:inmodule:LibFredo6_Loader'
/Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in<top (required)>' Error Loading File Fredo6_FredoCorner.rb Error: #<TypeError: can't convert nil into an exact number> /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:78:in-'
/Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:78:in<top (required)>' /Applications/SketchUp 2019/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:inrequire'
/Applications/SketchUp 2019/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:inrequire' /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_FredoCorner.rb:52:inmodule:Fredo6'
/Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_FredoCorner.rb:28:in<top (required)>' Error Loading File Fredo6_FredoSpline.rb Error: #<TypeError: can't convert nil into an exact number> /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:78:in-'
/Applications/SketchUp 2019/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:inrequire' /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_FredoSpline.rb:50:inmodule:Fredo6'
/Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_FredoSpline.rb:26:in<top (required)>' Error Loading File Fredo6_FredoTools.rb Error: #<TypeError: can't convert nil into an exact number> /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:78:in-'
/Applications/SketchUp 2019/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:inrequire' /Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_FredoTools.rb:47:inmodule:Fredo6'
/Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_FredoTools.rb:26:in `<top (required)>' -
Here is what I see in Extension Manager: (better now - earlier today the LibFredo extension installed as 'Unsigned'
https://www.dropbox.com/s/jibuoymuco6wn3n/Screen%20Shot%202020-08-27%20at%201.13.09%20PM.png?dl=0
Thanks for your help!
Iain,
Does LibFredo (and my other plugins) still load and work despite of that?
I cannot reproduce the problem on my Mac (Catalina and MBP too). So, I need to investigate why you get the problem.
Fredo
Iain
One thing to check is whether the binary file has been successfully copied.
Could you do the following in SU2019
Open the RubyConsole
Type
File.join(Sketchup.temp_dir, 'Fredo6_LibFredo6_TemporaryFiles') -
The console should display the result, something like
/var/folders/6_/9kz2gk_x7b70xbzsq4ghcpt00000gn/T/com.sketchup.SketchUp.2019.johnthorp/Fredo6_LibFredo6_TemporaryFiles -
Open the Finder and use the menu Go > Go to Folder (or Shift-Command-G) and type the result of the previous step in the prompt dialog
If you open the directory in the finder, could you check if there is
- a subfolder: binaries
- and within it a subfolder SU19 with a file bin_LibFredo6.bundle
If there is no file, then we have the explanation. This might be a problem of security settings.
If there is a file, then this is another problem.
@fredo6 said:
Iain,
Fredo
No, unfortunately not. No Fredo toolbars are showing up.
Did you reboot your Mac?
hallo , i have install on my Mac book last version of fredolibrary and new version of fredo corner, but have an error,
the precedent version goes whiteout any problem.
the error message after install and restart sketchup are the follow:
Error: #<LoadError: dlopen(/var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/com.sketchup.SketchUp.2019.diegoruina/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle, 9): Library not loaded: @executable_path/../Frameworks/Ruby.framework/Versions/2.5.5/Ruby
Referenced from: /var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/com.sketchup.SketchUp.2019.diegoruina/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle
Reason: image not found - /var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/com.sketchup.SketchUp.2019.diegoruina/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle>
/private/var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/AppTranslocation/E9C8BF29-3F67-4B14-99E3-C8AB0895B975/d/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:inrequire' /private/var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/AppTranslocation/E9C8BF29-3F67-4B14-99E3-C8AB0895B975/d/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:inrequire'
/users/diegoruina/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:610:inload_binary' /users/diegoruina/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:250:instartup'
/Users/diegoruina/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:inprocess' /Users/diegoruina/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:inmodule:LibFredo6_Loader'
/Users/diegoruina/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>' -
I am merging this into the main thread - where Fredo is more likely to see it !
thanks , sorry I don't see an other post exit.
for fredo6,
i ave look your message but system say I'm not able to reply at PM
last update I have manual cancelled any files of fredo lib and reinstall,
now go
NEW RELEASE: LibFredo6 v11.1c - 08 Sep 20
LibFredo6 11.1c includes various bug fixes.
Fredo
It looks like I completely missed LibFredo6 v11.1b, thanks for the update.
Error: #<ArgumentError: invalid byte sequence in UTF-8>
c:/users/정영호/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:ingsub' c:/users/정영호/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:inget_dir_from_ENV'
c:/users/정영호/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:425:insu_appdata' c:/users/정영호/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:443:indir_appdata'
c:/users/정영호/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:206:instartup' C:/Users/정영호/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:inprocess'
C:/Users/정영호/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in<module:LibFredo6_Loader>' C:/Users/정영호/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in<top (required)>'i experienced load errors.
Plz tell me how to fix it -
Fredo will reply in detail, but it looks like your Korean user-name [정영호] is causing the issue.
Ruby expects any text-strings to be UTF-8 encoded.
In earlier Ruby versions non-ASCII characters always caused problems.
In the newer versions of SketchUp there is text-encoding possibilities.
I know Fredo uses these latest methods.
But somehow your Korean user-name is almost certainly causing the problem...
Register LoginAdvertisement
