    [Plugin Library] LibFredo6 - v16.4b - 21 Nov 26
    2.3k Posts 597 Posters 16.1m Views 599 Watching
    • fredo6F
      fredo6
      NEW RELEASE: LibFredo6 v8.6j - 30 Oct 18
      LibFredo6 8.6j is for bug fixing and small GUI adjustments (size of toolbar icons for high-DPI screens).
      See plugin home page of LibFredo6 for Download of LibFredo6.
      Main Post of the LibFredo6 thread
      Fredo
      • fredo6F
        fredo6
        NEW RELEASE: LibFredo6 v8.6k - 03 Nov 18
        LibFredo6 8.6k provides new instructions for downloading FFmeg on Mac-OS platforms.
        IMPORTANT: the previous documentations included a link that is no longer supported and, worse, may have been hacked. So if you use Animator, please use the new link,
        https://www.ffmpeg.org/download.html
        Attached are the new PDF instructions
        Fredo
        Instructions_ffmpeg_Mac.pdf
        • Seatales45S
          Seatales45
          How does one update LibFredo6? Do I have to delete and reinstall?
          • fredo6F
            fredo6
            NEW RELEASE: LibFredo6 v8.6m - 18 Nov 18
            LibFredo6 8.6m is for Animator 2.3c (transparent background) and for the size of icons on hi-res screens.
            Fredo
            • fredo6F
              fredo6
              NEW RELEASE: LibFredo6 v8.6n - 05 Dec 18
              LibFredo6 8.6n fixes occasional problems in Orbiting, in FredoTools::ThruPaint and possibly in some others of my plugins.
              Fredo
              • fredo6F
                fredo6
                NEW RELEASE: LibFredo6 v8.6p - 05 Dec 18
                LibFredo6 8.6p fixes a random bug in Animator when using Movement Along Path.
                Fredo
                • fredo6F
                  fredo6
                  NEW RELEASE: LibFredo6 v8.7a - 18 Dec 18
                  LibFredo6 8.7a is a maintenance release providing adjustments to several of my plugins.
                  Fredo
                  • OxerO
                    Oxer
                    Hi Fredo,
                    I installed the last version of LibFredo v8.7a, there is an issue, I can't access to your plugins through the icons, it appears the options window and it disappears immediately. When I access through plugins Menu or Contextual Menu they work.
                    When the tool (ex. JointPushPull) is running and I push the Tool Settings icon it happens the same, the settings window appears and it disappears immediately.
                    macOS 10.13.6 & SU2017
                    http://www.oxervision.blogspot.com/
                    • fredo6F
                      fredo6
                      @oxer said:
                      Hi Fredo,
                      Can you open the Ruby Console.
                      Fredo
                      • fredo6F
                        fredo6
                        Do you have the problem with the button palette of my plugins (like JointPushPull or FredoCorner) or is it just for the dialog boxes?
                        • OxerO
                          Oxer
                          Nothing in Ruby Console. 😲
                          I open for example Window Menu> LibFredo Options> Check Updates for Plugins and the window appears but it closes immediately.
                          EDIT: After that I can use another Skechup Tools but if I press Cmd+Q (exit SU on Mac) SketchUp doesn't close, I have to force the exit.
                          • OxerO
                            Oxer
                            It's with the dialogs (popup windows) only, the palletes works fine.
                            How I said you before to access to yours plugins I can do this through the Tool & Extensions Menu or Contextual Menu only.
                            • fredo6F
                              fredo6
                              Is it for all popup dialog boxes ?
                              • pbacotP
                                I have loaded this plugin but my Fredo tools don't work. I get several prompts on opening SketchUp. According to the Plugin Manager I have the latest plugin.
                                • fredo6F
                                  fredo6
                                  Seems to be something quite old, because there is no longer a reference to LibFredo6 6.3 in the latest version of my plugins. Can you check for TopoShaper.
                                  Also, ff you run LibFredo6 8.7a, could you send me the trace file (Windows > Library Settings > Trace Log File...
                                  Another user has signaled me an anomaly with popup messages.
                                  Fredo
                                  • pbacotP
                                    Fredo
                                    I choose "View Trace Log Files..." and nothing happens. Let me try updating. I know most plugins are recent updates, but some like TopoShaper may not be.
                                    • pbacotP
                                      hmm... check for updates doesn't work either.
                                      • fredo6F
                                        fredo6
                                        Same problem as Oxer. You are on Mac, and there seems to be a problem with Web dialog boxes.
                                        Since you have FredoTools installed, could you check if
                                        • the Quick Launcher works
                                        • if Solid Volume displays a dialog box
                                        Fredo
                                        • pbacotP
                                          Ok updating several Fredo6 plugins allows me to open without prompts and FredoTools and Fredo Collection seem to be in place as before!
                                          Still when I choose "View Trace Log Files..." sometimes a window flashes on and off but nothing else happens.
                                          FredoTools Launcher doesn't do anything.
                                          Solid Volume flashes a window briefly.
                                          • fredo6F
                                            fredo6
                                            @oxer, @pbacot,
                                            Can you tell me which version of Safari you run on your Mac.
                                            It seems that Safari does not like a change I made in my code related to dialog boxes.
                                            Fredo
                                            • 67
                                            • 68
                                            • 69
                                            • 70
                                            • 71
                                            • 116
                                            • 117
                                            • 69 / 117
