    [Plugin] Put shadow on current day and hour
    22 Posts 10 Posters 18.2k Views 10 Watching
      Matt666
      Hi all!
      I created a mini-plugin that puts shadows on current date and hour. But when I try it, SU "forgets" one hour... I don't know why!
      Perhaps it depends of country it is installed and customized...
      So: Can you test it, and tell me if SU forgets this hour out of France??? Or can you tell me why?
      Thank you! πŸ˜‰
      %(#BF0000)[EDIT: Problem solved. Plugin works!
      EDIT2: Works well on SU V7 free and Pro. If you use an older version, please Jim's plugin to set your location.]
      Shadows=Now! in plugins menu
      Frenglish at its best !
      My scripts
        Is that work also with the free version who has only a default Days hours location place?
          Daniel S
          IΒ΄m in Argentina. My current time is 8:49 am and the plugin says 11:49 am.
          I think that the difference of three hours is because iΒ΄m in GMT -3.
          Daniel S
            Matt666
            Ok, thank you Daniel!
            Can you try code updated in the first post, please?
            Hi Pilou! I have a free version. So yes, it could works on it! πŸ˜‰
            My scripts
              Daniel S
              Now is working right...
              IΒ΄m happy with this version... my country is happy too!! πŸ˜›
              Thank you,
              Daniel S
                Matt666
                My scripts
                • W Offline
                  watkins
                  Dear Matthieu,
                  A brief explanation would be useful. I take it that your plugin updates shadows to the current, local time when selected. So, if I select the plugin at 15:25 Oxford UK time, the shadows show correctly for that location and time. Is that correct?
                  Regards,
                  Bob
                  • K Offline
                    KevinKarney
                    Hi All
                    To correctly display the shadow of an object, one needs the
                    "Local Apparent Solar Time" - which is a function of the Sun's altitude and azimuth in the sky at your particular location. The local apparent solar time is 12:00 when the Sun is due South (or North in the Southern Hemisphere).
                    Your watch and your computer indicate Civil Mean Time which is related to "UTC (Universal Time Coordinated)" - which is Atomic Time (and within a hair's breadth is the same as the out-of-date Greenwich Mean Time). Atomic Time is maintained by the Bureau International des Poids et Meseurs, which is a UN Agency. It averages out the time from a large number of atomic Cesium clocks around the world
                    Civil Mean Time = UTC + Time Zone + Daylight Saving Hours
                    Local Mean Time = Civil Mean Time +/- (the Longitude difference between your time zone longitude and your local Longitude) * 4 minutes
                    Local Apparent Solar Time = Local Mean Time + "The Equation of Time"
                    The Equation of Time is the difference between mean and apparent time. There is a difference between the two, since the Mean Sun (by definition!) is a virtual object that goes around the equator at a uniform speed, while the True Sun moves around the Ecliptic (23 deg to the Equator) at a non-uniform speed (in a ellipse). I attach a graph of the Equation of Time.
                    Confused.... But Sketchup has all this technology built in! It's shadows are spot-on for local apparent solar time.
                    Check this out 1) set June 14th when the equation of time is zero. 2) set your local Latitude and Longitude. 3) Draw a vertical stick. 4) Select the time around midday when the shadow is due North or South. The time you get +/- 12 will be the difference in longitude between your time zone longitude and your local longitude * 4.
                    Equation of Time
                    Best Regards
                    Kevin Karney
                      Yes but what about good Latitude, longitude inside the free?
                        Matt666
                        Hi Pilou!
                        I don't know. I do some tests, and Longitude/latitude parameter is customized in menu Window/Model info->Location.
                        Copy and paste code below in the ruby console, you will have all shadow infos.
                        Sketchup.active_model.shadow_info.keys.each{|k|puts(k+"; "+Sketchup.active_model.shadow_info[k].to_s)}
                        Hi KevinKarney!
                        Sorry, but I don't understand you problem (my poor english!!)... This plugin just putd SU shadows on the current date & time... Can you tell me what I should do to correctly display the shadow of an object? Thank you! πŸ˜„ If I able to..
                        My scripts
                          @Matt : this don't exist in the free πŸ˜’
                          Console gives that
                          City: Boulder (CO)
                          Country: USA
                          Latitude: 40.017
                          Longitude: -105.283
                          ShadowTime: Fri Nov 08 14:30:00 Paris, Madrid 2002 (Normal I have this regulate at this time)
                          I must verify what place is
                          Latitude: 40.017
                          Longitude: -105.283
                            http://download.sketchup.com/OnlineDoc/gsu6_win/Content/S-Common_Tasks/Tasks-SettingLocation.htm
                            Explains difference between Pro and Free Location Tools...
                              Jim
                              This is my solution for version 6 Free users:
                              Error 404 (Not Found)!!1
                              (sketchuptips.blogspot.com)
                              Version 7 Free does include the Location settings.
                                Thx for all these tricky solutions β˜€
                                  Matt666
                                  Aah, ok... Pilou uses V6!
                                  You are completely out, man! 🀣
                                  My scripts
                                    Yup,Location was not put into the free (Windows*) SU 5 and 6 but now with SU 7 it's there. Nevertheless by taking a GE snapshot, you can always "geolocate" your model (or use Jim's plugin)
                                    *Interestingly, it was only a Windows "(un)feature" only, as the Free SU 6 for the Mac has location. πŸ˜’
                                      Matt666
                                      Ok, thank you Gaieus!
                                      Exactly, watkins πŸ˜‰
                                      My scripts
                                      • P Offline
                                        Pout
                                        i would at this to your script:
                                        Sketchup.active_model.shadow_info["DisplayShadows"]=true
                                        This will immediately also show the shadow in the model.
                                        Otherwise one will not see the shadows if the are not set on
                                          remus
                                          Pout, turning on shadows as soon as you set them could be a little annoying, as it would lock SU up in a large model. Better to leave them off (if they are already off) and let the user turn them on, i reckon.
                                            Matt666
                                            Yep, that's why I didn't set shadows on in the code... πŸ˜‰
                                            My scripts
                                            • 1 / 2
