    Need help makeing screw edge
    26 Posts 9 Posters 4.4k Views 9 Watching
      It's about "Follow me and keep" plugin, Jeff. As it works,it will always keep the profile straight along the Z axis so you have the correct results (in this case) if you follow a spiral wound up along the Z axis.
      • takesh hT Offline
        takesh h
        i'm not really following this.. what do you mean by 'you are not getting your threads right at any points of the spiral except at the bottom' ?
        Oh this is a solved problem... sorry I didn't see the solution has been posted. Missed your model in post #8.
        I saw the image in post #11 and thought it's an ongoing problem.
        I was refering to blah11's quoted image in post #11.
        While I was looking at Jeff's model, an odd thought came down to me.
        This whole thing can be done without using Ruby - I'll explain.
        BTW you can do it as elements horizontally lying down (as in the image in post#11) with this method.
        A spiral with a single turn will do the job. This can be created by rotating a top face of a cylinder and multipy it vertically.
        Copy the spiral to match dimensions of the thread needed. Draw a cylinder with the same number of edges as the spirals and create faces between them. Erase unneeded faces.  Select faces that's to be the top of teeth, resize them gripping edge midpoint, in one dimension (width only), from center.
        Voila
        Now multiply the created geometry verticaly as many times as you need.
          Blah11
          OK its not the best but I am proud of my accomplishment heres a preview of the screw edge
          http://i228.photobucket.com/albums/ee18/Troopermanaic/1111.jpg
          I knew it would be valuable for me to come to this forum. Now is there a plugin that can turn things inside out? I would much rather do that instead of making the other edge which is a pain.
          • takesh hT Offline
            takesh h
            Look what you got there Blah, it's already reversed!
            I mean, it's a matter of which way you extend these thread surfaces as a volume, introverted or extroverted.
            Or am I missing something?
            Just group them and make a copy in the place.
            Keep modeling one of them as an internal volume, and the other as an external volume.
              Blah11
              I wasn't thinking when I modeled it I hollowed the inside, I guess it doesn't matter I found a different way to do the 2nd part anyway thanks,
              • gillesG Offline
                gilles
                http://www.crai.archi.fr/rubylibrarydepot/ruby/screw1_5.rb
                try this.
                • 2 / 2
