    Working on a UV mapping solution
    19 Posts 5 Posters 2.2k Views 5 Watching
    • C
      Colonel_Klink
      Hi guys.
      Been lurking about here for a while now. Found some great tips and have learnt a lot. Thanks to the contributors.
      I've been using SU for several years now, and use it as my primary modeling tool, for military models that I make. After they are made I usually import them into Max or Unltimate Unwrap 3D or my employer's proprietary 3D modeling software for UV mapping.
      Recently I've been experimenting with UV mapping in SU, and getting pretty fair results. While it is time consuming (I get paid by the hour), I have managed to UV map and layout complete models in SU. I intend writing a tutorial to share how I have done this, but in the meantime I'm trying to figure out how to do a couple of things to make life a bit simpler:
      1. Explode an object into individual planes (faces)and at the same time convert each plane into a Group and then make that plane into a component. At the moment I individually select each plane apply Group then Make Component.
      2. Automatically drop each component to the RED/GREEN plane and rotate it so that it is flat on that plane.
      • Chris FullmerC
        They could both be done with a ruby script. The first one would be fairly easy to write. The second one would not be much harder.
        I think you might run into problems though when it explodes a complex model instantaneously and flattens it and you have no clue what fece belongs where. Maybe you already have a fix for that though.
        Also, Jim has an unfold script. Its pretty cool. Check it out. It might help a lot. Perhaps it would make more sense to hand group the components and then use the unfold tool to flatten the faces.
        Chris
        All my Plugins I've written
        • C
          Colonel_Klink
          Thanks for your reply, Chris.
          I have used Jim's script, and you are right, it is pretty cool as I use it to unfold models to make in card. However the method I use to flatten a model for uv mapping involves keeping the base model intact and a copy is used to flatten the parts, hence the Group/Make Component step in the process.
          Although I program in VB and have done quite a bit of C++ type scripting for a game engine I haven't rolled my sleeves up and delved under the Ruby hood.
          I've attached a link to a very quick tutorial I knocked up to explain what i have been doing. If it prompts somebody to automate the process with ruby scripts or to develop it into a plugin, I'd only be too happy to help.
          http://www.resentmentpublications.com/downloads/SUUVMAP.pdf
          • Chris FullmerC
            Very cool, makes sense. I wrote a plugin but I'll have to post it after dinner in about 30 minutes....
            Chris
            • X
              xrok1
              nice technique, but rather lengthy process. if only we could get jim to rework the unfold to work with components made of single faces then the process would flow! 😉
              “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
              • C
                Colonel_Klink
                Thanks Chris. That is really cool. Does in a couple of mouse clicks what takes me normally a long time. One question though, how would I map that plugin to the right mouse button menu?
                • X
                  xrok1
                  Chris it would be really cool if you could modify your perpendicular tool to work with components. we'd have ourselves a real alignment tool in SU! usage: run script; click face of comp1; click surface to align to! 😄 this would be like the lay-on tool in Silo.
                  • Chris FullmerC
                    OK, this plugin will take all selected faces and turn them into separate components, like you show in the tutorial. Let me know if it needs to be tweaked.
                    Chris
                    UPDATE:
                    v1.1 Added the plugin to the right click context menu
                    v1.1
                    • Chris FullmerC
                      All right, I updated to add a right click context menu. You could also assign the script a shortcut key if you prefer that. I replaced the version that is up about 4 posts. So just re-download and overwrite the exitisng file if you had downloaded the old version.
                      As for aligning components....I think Didier might have made an align tool. I've never used it, but its probably available at the ruby depot. I don't know if does quite what would be required though.
                      Rewriting the unfold tool to work with components might be a bit trickier than with just plain faces. But it might be possible. Another option could be to write a script that would take all the single face components and rotate them around so they were all flat and on the 0,0 flat groundplane. Then the user could move them around, but at least the flattening would be done. Might not be helpful though, who knows.
                      Chris
                      • C
                        Colonel_Klink
                        hi xrok1
                        Yep it sure is a lengthy process, that's why I thought I'd share it with the group to see if someone can automate it a bit.
                        Jim's unfold tool is a really good starting point. The trick is to be able to create a macro recording of unfolding the model, then refold the model by reversing the unfold process after the model is mapped. The macro would record all moving, rotation steps, in say a text file, in much the same way as the undo feature in SU.
                        • C
                          Colonel_Klink
                          Hi Chris
                          Thanks for the update. This is super.
                          I'll have a look at that.
                          This tool could work if it were possible to record the unfold steps then reverse them to reassemble the model.
                          This would work if the flattening was done in small chunks, perhaps.
                          • X
                            xrok1
                            why not just copy the original then unfold that? i thought thats what you where doing?
                            the freescale ruby seems to be able to detect faces clicked inside components because it aligns the cage to a clicked face. the code is not scrambled either, hint hint. 😄 all you would need is to then rotate the face to match the next click, along a common edge. 😉
                            • J
                              Jim
                              Explain what do you want again?
                              I know (in my head already) how to keep history of the unfold precess and then have the plugin step backwards through the process (and not use the built-in undo.) It is just a matter of making time to implement and test it.
                              • X
                                xrok1
                                well instead of unfolding faces of (lets use a cube as our example) each face of the cube is being made into a seperate component but still in place to form the cube then copied. if this copy could still be treated by your unfold script as the original cube (non-component) would be, then it could be unfolded and used to texture thus updating the textures on the originally copied component cube.
                                • Chris FullmerC
                                  But if it has a built in "refold" process, it would not need to be turned into separate components. The idea then would be to take a component. Edit the component. Save that state of folding (no unfolding). Then unfold how you would like. Save that state as "unfolded". Then be able to switch back and forth quickly from folded (original form) to unfolded mode (flat form).
                                  So you could unfold your components and lay them flat. Edit their textres easier, then flip a switch and they rebuild themselves, with materials in place.
                                  That is how I think it should work.
                                  Chris
                                  • X
                                    xrok1
                                    that might be even better! 😛 the only problem i can see is if you want to use projected textures, won't they change when refolded?
                                    • R
                                      remus
                                      No, components (and all geometry, i think) hold their UV mapping after youve projected your texture.
                                      • C
                                        Colonel_Klink
                                        With Jim's tool you wouldn't need to create a copy of the original model
                                        that might be even better! the only problem i can see is if you want to use projected textures, won't they change when refolded?
                                        Remus is correct. If you project a texture to a face of a component or group the projection remains on the face.
                                        My orignial UV mapping consisted of a cube with projected mapped faces. I used this as my source to UV map models before this latest technique. It worked ok but I had to rearrange the uv map pieces in Max or Ultimate Unwrap3D or my employer's 3D program. Now With Chris' Make Component tool the process has sped up my modeling in SU. By laying out the pieces as in my tutorial the UV mapping is completed within SU meaning I have cut out a vital step in the other applications.
                                        Bob
                                        • C
                                          Colonel_Klink
                                          Chris
                                          Exactly what I have had in mind. Also, perhaps it would be nice to have a 'solid state' copy of the model while you unfold the other copy for texturing, that way you could quickly see if textures are lining up correctly as you apply them. But if that was too complex the quick unfold/refold options would be great.
                                          Attached is a model of a building I made today. I textured it from the materials within SU, then unfolded a clone of it using the technique in my tutorial, ably assisted by Chris' Make Component tool. The layout is for printing to make a paper model. While I can accurately scale it to 1/87 (HO) when I export it as an eps file it loses the textures when loaded into Illustrator. Why I havent figured out, but by loading into Photoshop at A4 300DPI I can apply textures to the model, and either print it or export as pdf.
                                          The large rectangles are the A4 page layouts. To save each layout I hide the others. it keeps the saved files tidier that way.
                                          Bob
                                          demo su house unfolded
