    I am starting modeling in detail. I need help!
    9 Posts 3 Posters 768 Views 3 Watching
    • P
      Physicsguy1
      first off some may be surprised i am asking for help. If you have an account and use the plugin sketchyphysics, you most likely will know me. I excel in programing mechanicals doo-dads and the like with sketchyphysics, but i have taken in other interests, like airplane design. I need help. Normally i use a push and pull technique, which does work well, but after comparing my outputs to other models, i look like i started new. I don't get how they model them perfectly! I tried using plans and arranging them in the order so you can draw an outline on the three axes, like other modelers, but it ends up looking strange. I am forced to create my own designs, partly because I don't want to embarrass myself uploading a famous plane that looks like a mutated pig(that was a bit over-exaggerated, but you hopefully get the idea).
      • P
        Physicsguy1
        Here is one model that i should show that i had to build from my mind. While, in my opinion, the mechanics and the whole inside is outstanding, but the fuselage shape looks terrible!
        plane.skp
        • T
          Teezer
          I've done a couple of airplane models, and this is the method I used:
          Make the guidelines a group so your built-up fuselage doesn't stick. As the curves get sharper, your pulled sections will be smaller. Make them small enough to give you a smooth curve.
          Here's where I posted my (sailplane) models: http://www.sketchucation.com/forums/scf/viewtopic.php?f=81&t=9647
          Real life is just another website, albeit a rather boring one.
          • P
            Physicsguy1
            I have tried it before. The real trouble is around the canopy. i have to project the curve , which is annoying. And if you notice, the models on the warehouse have the "nice" lines. I mean like all the details that are outlined which cannot be modeled. If you notice all the panels on aircraft of older times, that is what i mean. i have tried intersection, Nut the warehouse models always look better. I will see.
            • T
              Teezer
              If you're trying for accuracy for the recurved areas around the canopy, you just have to draw the detail curves by hand. If you're not duplicating a model exactly, Whaat's Subsmooth ruby will make things easier.
              Not sure what you mean by "details that are outlined that can't be modeled," unless you're trying to keep things low-poly.
              • P
                Physicsguy1
                I'm sorry. I meant like outlining panels.
                • X
                  xrok1
                  use toolsonsurface to draw panels on the fusalage then jointpushpull to extrude them. 😄
                  “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                  • P
                    Physicsguy1
                    Huh? those tools don't sound familiar
                    • X
                      xrok1
                      when you discover scripts you'll discover the true power of sketchup grass hopper. 😉
                      here are the links: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11212
                      http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=6708
                      ENJOY!
