    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    Need help: get length of arc/spline
    12 Posts 4 Posters 946 Views 4 Watching
    • H Offline
      huyvuvn
      Anyone have the ruby that can do getting the LENGTH of ARC or SPLINE ? please share with me , many thanksssss
      cheerssss
      happiness on the way, not in the destination.
        If you select edges and arches the Entity info will give you the total length.
          You must explode "arc" before else you have only radius ๐Ÿ˜‰
          • jeff hammondJ Offline
            jeff hammond
            no, there's a drop down button in the entitiy info window that you can push which will give more info on the selected entity. i can easily find the length of an unexploded arc.
            [this is at least capable on macs though i can't imagine it not working on windows]
            http://homepage.mac.com/jeffhammond/.Public/scf/entityinfo.jpg
            http://homepage.mac.com/jeffhammond/.Public/scf/entityinfo1.jpg
            dotdotdot
              Thx! Never used for arcs! ๐Ÿ˜ณ
              • H Offline
                huyvuvn
                thanks all , I know this way. But I wanna "GET" the length , not "KNOW" the length. It means have a "dim".
                  jeff hammond
                  ok huyvu, you're obviously asking something but it's probably above me..
                  to me, getting the length means finding out how long the arc is.
                  maybe "get" is a calculus term that i've never heard of but i really can't figure out what you're wanting to achieve.
                  the only thing i can think you may be wanting to do is enter a radius and desired length of arc and sketchup will draw it. if that's the case, i personally don't know of any method to achieve this in SU.
                  do you have a visual example which may show the difference between getting the length and knowing the length?
                  dotdotdot
                    ๐Ÿ˜„
                    before a plug
                    just use the tape measure tool on a segment of the arc and enter
                    length of a side / (existing length / length wished) (given by the Info)
                    Your drawing will be resized with the good length of the arc ๐Ÿ˜„
                    Example : you have an arc of 5 sides for a length of 600 cm so a side = 600/5 = 120 cm
                    you want your arc = 100 cm
                    you will enter 120 / (600 / 100) = 20 cm ๐Ÿ˜„
                    As all will resize, you must export in a new session your arc apply the resize above and import it after the redraw ๐Ÿ˜„
                    Seems not many more difficult for a plug ๐Ÿ˜‰
                      Ok, you want a Dimension tool for arches and splines.
                        Can anybody can say why the length is false with this big % of error ??? (2.75%) ๐Ÿ˜ฎ
                        must be
                        why.skp
                          must be
                          5 * 120 = 600 and not 616.5... โ“ โ“ โ“[attachment=1:h1pwt2lb]<!-- ia1 -->why.jpg<!-- ia1 -->[/attachment:h1pwt2lb]
                          Because SU calculate the length as if it is a perfectly round arch. I bet that it gives the 'correct' length if you explode it.
                            if you explode it
                            Yes but it's dangerous to manipulate TNT ๐Ÿ’š
