    [Plugin] Material Tools
    124 Posts 44 Posters 179.1k Views 44 Watching
      Sir
      very useful plugin thomthom. is it possible to add the functionality to remove ALL materials but ONLY from the selection?
      fantastic!
        fantastic!
        Yea, that would be possible. I was thinking of doing that anyway. πŸ˜‰
          Sir
            Only one thing; what would be the expected behaviour if the selection contains an component instance?
              Sir
              id have to say that remove from all instances too, as you'd want them all the same, no? suppose it could always be a check before compleating the script tho, im sure someone would want it both ways!
                Can't you just use my GlobalMaterialChanger.rb ? ... It works on a selection, OR the whole model... and it asks if you want to 'mine' down into groups and instances etc...
                  Sir
                  i wasnt aware of it... ill go take a look πŸ‘
                  • P Offline
                    Pout
                    great! Thx!
                      Hi Thom,
                      sorry for bumping the topic... Could you add "Remove materials applied to back faces"? (Or is there a plugin that does that already?)
                        Al-ka-zam!
                          @gaieus said:
                          Hi Thom,
                          http://forums.sketchucation.com/viewtopic.php?p=264134#p264134 = My recent tools include three options:
                          1. If a face has no front-material but does have a back-material it reverses the face and moves the back-material onto the front keeping the UV mapping etc. It works on selected faces, and after a confirmation-dialog faces in groups, components, or just 'all'.
                          2. If a face has a front-material and also has a back-material it reverses the face and moves the back-material onto the front keeping the UV mapping etc and erases the other material - i.e. the back-material is finally defaulted [it is 'forced' - use with care!]. It works only on selected faces.
                          3. It removes back-materials from all selected faces, and after a confirmation-dialog faces in groups, components, or just 'all'.
                            πŸ‘
                            Cool, TIG, thanks! I knew I remembered reading something but you guys spoil us with the abundance of new plugins every day so it's really hard to keep up with the development!
                            πŸ˜„
                              Ben Ritter
                              Thomas, thank you.
                              • Z Offline
                                Zacchia
                                thanks for this plugin!!
                                  Some various updates to this plugin - renamed it as well.
                                    caleidos4d
                                    Thanks thomthom πŸ‘ πŸ‘ πŸ‘
                                    http://www.caleidos4d.it
                                    • CAntonisC Offline
                                      CAntonis
                                      Thank U.
                                      It 'll come in handy! Thats for sure!
                                      CAntonis
                                        dedmin
                                        Instance Material to Faces paints materials also to the back faces. Apply Color Adjustments bugsplats SketchUP when nothing is selected. The names are somehow misleading because this tools work on a selection - maybe to put them on the right click menu when click on the selection or add "selected" to the name.
                                        WinXp SP3
                                        SketchUP 8
                                          Yes - by design to preserve the same visual appearance.
                                          😲 It doesn't use the selection at all - it processes all colour adjusted textures in the model. Got a sample model where this occurs? I've not seen any bugplats with this. Can't reproduce it either.
                                          Not all work on the selection.
                                            dedmin
                                            Itis a clean file - nothing there
                                            • 6
                                            • 7
                                            • 2 / 7
