    Su podium prroblems with pictures please help
    11 Posts 6 Posters 1.5k Views 6 Watching
    • Z
      zumo
      I have a problem !! When I bring in a picture into a drawing then render it seems to not be the way I would like it to as you can see in the pictures bellow..........
      I am using su render for rendering
      Thank you.
      • Z
        zumo
        Thank you.
        • BurkhardB
          Burkhard
          explode it
          http://www.ia-plus.de
          • Z
            zumo
            @burkhard said:
            explode it
            I tried but still no luck
            • soloS
              solo
              I am not sure exactly what is wrong or what you find wrong.
              http://www.solos-art.com
              • thomthomT
                The picture of the kid on the wall. I isn't positioned properly as you see from the SU screenshot in the bottom image attached in his post.
                • soloS
                  solo
                  LOL, sorry i missed that, i was looking at the over smoothed geometry.
                  Try painting copying the image on back and front face (exploded)
                  • BurkhardB
                    Burkhard
                    I miss that too, sorry for to be fast
                    • honoluludesktopH
                      honoluludesktop
                      If all things fail, and you don't care what the SU scene looks like, try enlarging the SU photo image texture about 2X, pinning the lower right corner to the frame (adjust if necessary). I would also blur the photo a bit, consistent with the overall level of detail.
                      • S
                        sepo
                        I suggest you import picture not as a texture. Stretch it to fit the frame. Explode it. It should render correctly.
                        • Z
                          zumo
                          thank you all so much for the advise it worked !!
                          god bless this forum
