    [Plugin] Scale and Rotate Multiple (UPDATED Dec 22, 09)
    123 Posts 51 Posters 223.3k Views 51 Watching
    • utilerU
      utiler
      @pixero said:
      Here is a mockup of a possible interface without a fancy web dialog.
      "Scale about" is same as current version.
      Should maybe change name to something like: "Origin"
      [attachment=0:1zxmxinr]<!-- ia0 -->MockUp.jpg<!-- ia0 -->[/attachment:1zxmxinr]
      Great idea, Jan!!! Chris do you see this being implemented....?
      Cheers,
      Just Curious...
      • plot-parisP
        plot-paris
        @chris fullmer said:
        I am learning how to use web dialogs, so once I get that down, I would be interested in trying to update some of these scripts
        great things to come then... I can't wait to see what you are going to come up with πŸŽ‰
        • Chris FullmerC
          That's some good pressure πŸ˜„
          Andrew, yeah if I can ever get around to these updates I dream of, that is something I would like to add.
          Chris
          All my Plugins I've written
          • utilerU
            utiler
            Cool, appreciated all you have done for SU workflow.... πŸŽ‰
            Just Curious...
            • X
              xrok1
              now where's that bump button ❓
              β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
              • M
                MartinRinehart
                Chris, is it HTML, JavaScript or the linkage between these and Ruby (or all three)? I'm planning a frontal assault on the latter (rewrite Lininger but going much slower) which I could kick up to the front of the line. I've done HTML (http://www.easyHTMLtutorial.com) and am mulling on JS.
                Martin
                Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
                • Chris FullmerC
                  Hi Martin, I'm not even sure what it is that is holding me up. I don't know HTML at all. I don't JS at all. And I have no clue how they interact. So reading through JS tutorials leaves me confused because I don't understand what its doing tot he HTML. Reading through HTML tutorials seems to help the most currently. So I will gladly look over your HTML tutorial.
                  Chris
                  • plot-parisP
                    plot-paris
                    just a big THANK YOU!!! again, Chris.
                    you saved me about 15 minutes rotating and scaling a whole bunch of trees... 😍
                    • D
                      DIEGO-RODRIGUEZ
                      hi Chris
                      I proposed an idea on the forum.
                      viewtopic.php?f=180&t=22569
                      If you have not seen her.
                      I think your plugins, could adapt well to the idea
                      interested? is possible?
                      greetings
                      • majidM
                        majid
                        recently I saw this. thank you for generousity
                        • Chris FullmerC
                          I just got a report that this might not be working right in 7.1!
                          So if you use it and it moves components all over th place, instead of just scaling them, please let me know. I need to look into it.
                          But otherwise I hope you find it useful πŸ˜„
                          Chris
                          • Chris FullmerC
                            Can any Mac users verify if this script is working on SU 7.1? It appears to working great on Vista, SU 7.1 but I still have a report or two of it not working.
                            Anyone have any example files where it is not working for them?
                            Chris
                            • thomthomT
                              Chris
                              SU 7.1M1, OSX10.4
                              AΒ΄OK!
                              • Chris FullmerC
                                Thanks Thom!
                                I should mention what is not working for some, just in case you just verified it loaded.
                                I have heard 2 or 3 reports of this plugin thoring components all over the place, instead of using their axes. It seems that for some, this plugin does not scale and rotate according to the specified axes.
                                So if anyone still feels like testing further, awesome. Otherwise, I'll write a debugging version and give that to anyone who wants to test it out, see what is broken on their system.
                                Thanks again,
                                Chris
                                • thomthomT
                                  I just tried the random rotate and scale. That worked as expected. But if you have specific procedures that's reported to fail, then I can try that.
                                  • PixeroP
                                    Pixero
                                    Yeah, I've seen that two times recently when using axis.
                                    When I choose component base everything was o.k. though. ❓
                                    • Chris FullmerC
                                      Has it been on all components? or is just on face-me perhaps?
                                      • thomthomT
                                        I tried with groups, components and face-me components. Can't reproduce.
                                        ...maybe it has to do with nesting..?
                                        • thomthomT
                                          just noticed something when orbiting after random rotate and scale; face-me components float about all over the place.
                                          • thomthomT
                                            that also occurs on PC.
                                            See attached file for a sample of dancing Sang! πŸ˜†
                                            dancing_sangs.skp
                                            • 6
                                            • 7
                                            • 3 / 7
