    How to select everything on a layer
    11 Posts 3 Posters 1.5k Views 3 Watching
    • P Offline
      Prisoner
      Long time reader, first time poster starting with a silly question.
      I've been using Sketchup some time for fun, now starting to use it for a small commercial RPG Project (maps for oldschool tabletop roleplayers).
      Here is my problem: Is there an easy way to select everything on a specific layer?
      Let's say I have layer "1st floor" and layer "1st floor object". All the groups and components belonging to "1st floor objects" sit inside the a big 1st floor group, which belongs to layer "1st floor". That way I can switch off the floor with one click, but now I want so see only the stuff on layer "1st floor objects", but cant.
      I hope it's just my legendary blindness for the most obvious solution ๐Ÿ˜•
      Thank's in advance (and for the countless times you made my work with sketchup easier without me saying thanks)
      Pris
      • X Offline
        xrok1
        you would need to take the out of the group. another way is to select just the faces in "1st floor" layer group and put those on "1st floor" layer, but keep "1st floor" group on "1st floor objects" layer that way when you hide "1st floor" layer, only the faces will be hidden.
        โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
        • X Offline
          xrok1
          check this file. i turned color by layers on to make it easier to see. its kinda a confusing concept so play with this for a while. the jist of it is that a group can be on one layer and includes everything in
          it. but its faces can be on another layer and hidden seperatly.
          layers.skp
          • X Offline
            xrok1
            BTW, what you asking "how to hide things" is different than "how to select things" which is the title of your post, so i hope i answered the right question. ๐Ÿ˜‰
              The solution - with layers "embedded" or "nested" each other - could only be justified and useful if the layer system would also be "tree like" (such as grouping for instance). Since it is not but only "linear", you should always avoid scenarios when entities belong to several layers through nested groups (or components) except for Layer 0 where all your primitives should be sitting.
              So do what Xrok suggests; get the nested content outa' there somehow.
              • X Offline
                xrok1
                Gaieus, wouldn't it be nice if someone would ruby a scene manager that combined all these elements, outliner, layers, styles.... ๐Ÿ˜„
                on that note isn't it strange that google themselves never seem to release any ruby's. included ruby's ,centerpoint... aside? ๐Ÿ˜
                  Oh sure. And I've been yearning for a tree like, collapsible layer system such as the Outliner for instance. Or better say the system itself, not only the management window.
                  • P Offline
                    Prisoner
                    Thank you xrok1 and Gaieus. Nested groups on different layers have been very useful up to this point for controlling visibility. Seem like the usefullness is at its end now.
                    Like you said, it seems I have to get the nested content out of the "master group". That brings back the question of how to select everything on a specific layer. Is there an easy way to do this? As far as I can see "select all on layer" works only for lines/faces, not for groups/components.
                    • X Offline
                      xrok1
                      it does work for groups or components but strangely enough ๐Ÿ˜’ you have to have at least 2 selected; can be 1 face and 1 group or 2 groups/components; to envode the select>all on layer option ????
                      • P Offline
                        Prisoner
                        Perfect! Selecting 2 things did the trick. Thank you so much โ˜€
                        • X Offline
                          xrok1
                          strange isn't it? it should be in the menu in the layer manager too.
