    Needs help inserting a background??
    10 Posts 4 Posters 960 Views 4 Watching
      jcarchitecture
      I'm rendering a swimming pavillon that is situated of water. In the beginning, I owuld render my own water but when inserting the background I have, it doesn't look right. So then I rendered without water but noticed that when looking through the glass, I wouldn't be able to see my image behing the glass because it is an image. All I want is to have my background pic with my render , how to I combine the two?
      • X Offline
        xrok1
        i would probably make a plane (face) in the back behind the building, see red box (image) but put in background. then use the picture as the texture on it so you can see it through the window.
        this is the easiest way. there are other techniques but they require post processing in photoshop or similiar.
        “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
        • X Offline
          xrok1
            jcarchitecture
            Thanks alot bud! You say you ask questions often, but you must have skills. You can send me some pics of what you do and even give me suggestions.
            • X Offline
              xrok1
              i spend most of my time playing with settings. here are some experiments:
              • X Offline
                xrok1
                really the design is more my thing, but i just can't resist trying to make a good render?
                  jcarchitecture
                  Dude, nice rendering and design. I'm actually doing my portfolio right now s o touchin up my renders. I really like the render where the guy is standing by a bassin. Can you tell me how you made your water material?
                  • X Offline
                    xrok1
                    yeah, you gotta check this out, http://www.xiberpix.net/SqirlzReflect.html
                    just render your flat water then use sqirlz to enhance the water, it awsome!
                    kesreflect.SWF
                    • FrederikF Offline
                      Frederik
                      It's really difficult to answer your question, without knowing what render application you're using... 😐
                      Just by looking at the image, my immediate thought would be Kerkythea or Podium...
                      My knowledge about how you do this in Podium is limited, but if this is a render you're making in KT, then I can encourage you to read page 28 in the Getting Started - KT2008 Echo tutorial... 😉
                      Hope this can help you further...?!? 😉
                      Cheers
                      Kim Frederik
                        Is that the sky you see in the window? You should get an alpha channel you can use if you have it enabled in the VFB section of V-Ray.
