    Intercept Mystery
    3 Posts 3 Posters 516 Views 3 Watching
    • JoelM3DMJ Offline
      JoelM3DM
      I want to cut a hole in a face where an item, say a box, goes through it - so I do Intercept With Model. This gives me a rectangle where the box met the face, just like I want. Sometimes the face is cut like I'd expect and I can select and delete the hole. However, sometimes the lines are lying on top of the face and the face won't divide. I can't figure out why it works sometimes and only sometimes. Frustrating! - Joel
      || Joel Metzger 3D Modeling
      || story-shorts.net - Animation with SU
      • V Offline
        Voder Vocoder
        On the occasions when the lines just sit on the face without cutting, is it possible that the object you're intersecting is a group or component? You can't get a complete mutual intersection between two objects unless they're in the same context, meaning they're either in the same group or component or none at all.
        ~Voder
          AndriyG81
          an example file would be very helpful πŸ˜‰
          Intersecting grouped geometry will behave differently from simply intersecting ungrouped geometry. Try experimenting. The behavior of lines "just being on top" usually happens when you deal with grouped geometry.
          http://andriyg.com
