    Podium?
    extensions
    8 Posts 4 Posters 1.1k Views 4 Watching
    • X Offline
      xrok1
      i personally don't find the podium documentation too good and would like to start a place to ask questions about it. (i know they have their own forums but i'm here... and so are you.LOL)
      so i'll start. is there a way to reverse the direction of bump maps without taking them to PS and inverting them? something like "name_bump-2" , which incidentally i tried and it does not work.
      PS feel free to leave any podium tricks you have up your sleeve, here. 😉
      “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
      • EdsonE Offline
        Edson
        sorry, but you will get much more info at the podium forum. there you will discover that there is good documentation available. i suggest you make your questions there. this is a sketchup forum, do not forget it.
        http://www.mahfuz.arq.br
        • Mike LuceyM Offline
          Mike Lucey
          Hi xrok1,
          I can see your point about some Podium discusion. It makes a certain amount of sense remaining in a single forum to discuss SketchUp and related applications. Maybe we should talk some more about this?
          Mike
          • X Offline
            xrok1
            Edson, Board index ‹ Google SketchUp Community Forums ‹ Extensions & Applications Discussions sorry to disagree, but can we have a conversation now?
            • soloS Offline
              solo
              Try adding a ground plane, also adjust shadow tones with 'Dark' slider in Shadows drop box (The Light slider does nothing in podium)
              Another option is experimenting with backround tones, as that effects renders.
              There are many free .xml presets available on the podium frum for different render types.
              http://www.solos-art.com
              • X Offline
                xrok1
                here's another question or observance:
                default light no shadows, no use sun for shading
                default light with shadows, no use sun for shading
                default light with shadows, and with use sun for shading
                my question is, how can i achieve the nice lighting from scene1 with the nice shadows in scene3. does anyone know what the Light/Dark settings should be, or what SU default Light value is.
                there seems to be some sort of ratio between light and dark i just can't put my finger on.
                • X Offline
                  xrok1
                  solo, wow 😲 you just blew my mind, thankyou. i couldn't believe the light slider didn't do anything, so i set out to prove it to you, then i discovered you're absolutely right. boy did you ever make my life easier, i've been tweaking and tweaking light to dark ratio's forever LOL. i'm sure glad i started this thread it changed my rendering life forever. thanks again.
                  i do think i found my setting.Dark=4:
                  any advise on the negative bump issue? i discovered you can reverse faces but its not really feasible.
                  these are from Podiums site: bump_sample.zip
                  this one has the bumpmap inverted in PS:
                  • X Offline
                    xrok1
                    BTW, is there any way to soften reflections?
                    PS its too bad the lighting dosn't work like you'd expect, light controls overall brightness and dark controls contrast of shadows.
