Help with Arcs and Faces
Hi everyone
I'm new to SU. I've been using it for just over two weeks and have created various simple projects to work through the tutorials. I've found lots of help on this board, so thank you to all.
I am having problems with creating faces from arcs. I've searched through the forum and have been using Sandbox Contours to create faces, but now I'm stuck. I attach a wireframe jpeg. Can anyone offer any guidance? A big thank you!
Hi Sablon,
First of all (although this is unrelated to your problem), don't use those sketchy styles for modelling! Many of the details will be hidden and you cannot see everything precisely.
Now back to your model; what I'd do is to use the side faces of that armchair and push-pull them to give a thickness to it. This way you could spare stitching those curves together.
If you upload your model here, I can show what I mean.
Gaieus, thank you for your advice. I'll try the push pull (and use default styles) and see what I come up with. I'll post the results.
Register LoginAdvertisement
