    I'm back!
    13 Posts 8 Posters 1.7k Views 8 Watching
    • Paul RussamP
      Paul Russam
      Hello peeps, long time no speake.
      I’ve not posted here for quite some time, the reasons being varied and mostly rather pointless. Initially it was because I was ill with a batch of my cluster headaches, then it was because I didn’t have anything to post about and then it became weird.
      I wanted to post but because I hadn’t for some time I didn’t! The longer I left it, the harder it became to post here, Odd don’t you think? I’m sure there’s a name psychologists give to such situations: ScaredaPostaPhobia sounds good.
      I haven’t been avoiding the site completely as I visit regularly to see what’s happening and steal ideas (did I say that out loud?)
      Recently I’ve been attempting to produce some images on a daily basis, finished or not.
      I waited until I knew I would keep up the process before posting here. I’m very good at starting something only to abandon it having sated my need to have done it in the first place.
      Below are some links to the Picasa albums I’ve knocked out already.
      2009-01-30 - http://tinyurl.com/aw4v6p
      1 Image of a church we’re extending and a bunch of images showing the roof structure of another church (yes that one)
      2009-02-02 - http://tinyurl.com/dnkgpb
      A building we’re converting to a nursing home, this is the existing building, I’m in the process of building the proposed interior.
      2009-02-03 - http://tinyurl.com/c8unel
      Old school building in Dublin we’re converting to multi-use (class rooms, offices, bedrooms etc). This model will eventually be finished down to the plug sockets and light switches.
      2009-02-04 - http://tinyurl.com/dz858o
      The same project as above.
      2009-02-06 - http://tinyurl.com/cx56sp
      That church! This is the first attempt at a proposed stair to the choir gallery, it had too many problems and was redesigned (see later)
      2009-02-09 - http://tinyurl.com/bb3jyv
      That church again! (This will be a reoccurring theme) Finally got the back of the exterior model started, I’ve also got some photos of the real thing in here.
      2009-02-10 - http://tinyurl.com/bjtecv
      TCA. More of the external model, the sanctuary this time.
      2009-02-11 - http://tinyurl.com/cn5ha9
      TCA. The exterior is finished! Just the ground to do now.
      2009-02-12 - http://tinyurl.com/apdyk7
      TCA. Ground, railings, walls etc. done.
      2009-02-13 - http://tinyurl.com/dcvjyw
      TCA. Back to the stairs, not quite there yet.
      2009-02-16 - http://tinyurl.com/c4kmuk
      TCA. Lots of small stuff today, so no real progress to show, so I thought I’d post a bunch of images of the whole model. Those of you that remember the model will notice that I’ve now got the whole interior done, no more massive opening in the model where the front door should be.
      This is also the proposed design, you will only have seen the model of the church as is before.
      2009-02-17 - http://tinyurl.com/ddtazp
      TCA. The stair AGAIN! This time its finished (well sort of) The stair lift is most definitely going, I think we’re going to propose a catapult instead.
      2009-02-18 – That’s today dam it, give me a chance!
      Well that’s it then, hello again and if anybody’s using twitter I go by @Rollothecat
      Lets see if I can keep this up this time and keep my ScaredaPostaPhobia at bay.
      Paul Russam
      English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
      • B
        bubbalove
        You attention to detail is astounding! Good work and thanks for sharing...
        PS - Do you think that you will get around to finishing your Animation Tutorial?
        "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
        • GaieusG
          Hi Paul,
          Glad to see you back (especially with that church - you know I'm a fan of it but who isn't?). Unfortunately it's either Picasa or my internet at work here (it seems to have serious problems with Google products), I could hardly see a couple of images and it started to hang. Thank God my office hours are just over so I'll have a better look at home!
          • soloS
            solo
            Hey Paul, welcome back.
            I was wondering what happened to you, thought for a moment you got into a scrape in the corner bar or something.
            Very happy you overcame your 'ScaredaPostaPhobia' 😉
            http://www.solos-art.com
            • Paul RussamP
              Paul Russam
              Thanks Guys, I've missed you (Gush)
              I nearly forgot, this is a 280Mb QTVR of the interior of the church, there are around 50 clickable hotspots within the file, wherever you see a red figure you can click and jump to that POV, also there are ones high up that look like round arrowy things.
              Forgive the initial hotspot, its not quite finished yet. I'm planning to add a load of hotsopts of the outside (planning anyway)
              You'll be downloading this from my Dropbox so I have no idea how fast it'll download or how many can download it before Dropbox has a hissy fit.
              I would recommend that you right-click and 'Save link as' otherwise you browser will almost definitely try and open the file in a new window.
              Let me repeat - 280Mb, you've been warned!
              http://dl.getdropbox.com/u/373226/1287-QTVR-V2.mov
              Paul Russam
              • B
                bubbalove
                Very cool... what software did you use to make the Animation?
                • Chris FullmerC
                  Hmm, all I'm getting is a white screen from the qtvr. If I click on map, the map shows up, but the hotspots don't seem to work. Just a white screen. Anyone else?
                  Chris
                  All my Plugins I've written
                  • B
                    bubbalove
                    It worked for me but it takes a little while to load...
                    • boofredlayB
                      boofredlay
                      "ScaredaPostaPhobia" is a rare condition which has only been reported on the Emerald Isle in the past 10 years +/-. I think Mayor Mike suffers from a mild case.
                      In my extensive studies which lead me to a P.H.D. (Pretty Horrible Delusion) from the University of Buhel Sheittia, ScaredaPostaPhobia is easily overcome by allowing friends to compliment your work. One compliment is enough to break the cycle thus releasing the fear of posting incredible work.
                      Fortunately I have never suffered from ScaredaPostaPhobia.
                      We used to have a 12 step program for this on the forum but I believe it was folded into the Corner Bar.
                      DANG Paul, nice to see you posting again!!!!!!!!!!!
                      Great work as usual.
                      I was just thinking about you the other day and wondering if your headaches had gotten any better. Phoey on me for not asking. But I am happy to hear you are better.
                      • Paul RussamP
                        Paul Russam
                        Thanks for the comments, its nice to be back.
                        Did anyone get the QTVR to work?
                        Here's todays IOTD
                        2009-02-18 - http://tinyurl.com/bj7o3c
                        A lot of work but not much to show today, I'm in the process of building and locating all the radiators, sockets, light switches, furniture etc. This is not what we'd normally do but its been 'deemed' necessary on this particular job.
                        Quick note regarding the colours.
                        I create materials as I go along, Circulation-Floor, Circulation-Walls, Office-Floor, Office-Walls, Toilet-Floor, Toilet-Walls etc etc. I give them bright contrasting colours so that if I accidentally paint a toilet wall with the office wall material it will stand out like a sore thumb. Its only near the end of the build will I adjust the materials to match the purpose of the model.
                        Paul Russam
                        • S
                          ScottPara
                          Paul,
                          Amazing work! What software did you use for the hotspots? Very cool.
                          Scott
                          Love the fact that some HATE my avatar.....
                          • Paul RussamP
                            Paul Russam
                            I used the CubicPanOut ruby to generate the 6 images from each location
                            Moved all the images to my Mac
                            Used Cubic Converter to make the 50odd single QTVR's
                            Then Cubic Connector to link them (Dam laborious work) and export as 1 QTVR
                            Cubic Converter: http://www.clickheredesign.com.au/cubicconverter/
                            Cubic Connector: http://www.clickheredesign.com.au/cubicconnector/
                            Paul Russam
                            • troyhomeT
                              troyhome
                              absolutely astounding work! wow.
                              IOviz.com
                              SU Pro 2024 PC
