    Windowizer without window frames?
    5 Posts 3 Posters 786 Views 3 Watching
    • K Offline
      kwistenbiebel
      Hi all,
      I am trying to divide surfaces in rows and columns but without window framing.
      If I put all the framing sizes to 0 in the windowizer panel,it still shows (a minimal) frame.
      How can I overcome this?
      Is there a ruby I am missing?
      Thank you in advance
        Hi kwist,
        I'm not sure what exactly you are after but how about just arraying edges horizontally and vertically to divide a face?
        • K Offline
          kwistenbiebel
          Thanks Gaieus for your answer. 👍
          I ended up doing it that way (array some lines horizontally and vertically).
          Since I have complex surfaces (non quadrangular) to 'array', I thought a plugin might be useful.
          Actually, what I need is the ability to draw a complex grid and project it to surfaces ....
          The grid is somewhat irrecgular , following a rythm (e.g AABA ABBA AABA etc...) and shifted per row.
          I never used the 'projection tools', but can I use it for that?
          • Wo3DanW Offline
            Wo3Dan
            @kwistenbiebel said:
            ....I never used the 'projection tools', but can I use it for that?
            Hi kwist,
            The 'Drape' tool will "drop" a selection onto a surface. But it will only work verticaly meaning you need to temporarily rotate the things you are working on.
            Note that the 'Drape' tool drapes on multiple connected faces/surfaces above each other.
            On the other hand there are some ruby scripts that you can apply for this job.
            One is called: projection_v6.zip with its own toolbar.
            Or an older one that works with projecting faces (not 'stand alone' edges): project_faces_plane.rb
            (Both from Didier Bur)
            Success,
            Wo3Dan
              Yup, these should do the job perfectly. 👍
