    Manhattan sketchup model
    60 Posts 21 Posters 25.8k Views 21 Watching
    • N Offline
      nightzombie
      hello everyone
      i have been digging around internet for more detailed model and came across
      a 3ds file with much more detail from central park to union square area
      (With topography!) ๐Ÿ˜ฎ
      i'm having trouble converting the file to sketchup for number of problems.
      1. scale is too small
      2. too much polygon count
      3. model is oriented in weird angle
      4. everything is on one layer but with each building grouped
      i tried optimizing the file in order to import it into sketchup but after
      two hours of importing, it came to an error ๐Ÿ˜
      can someone help me import this 3ds into skp format?
      http://www.mediafire.com/file/myuwknlz2zj/16413_New_York_City_USA_Top_Quality_Part_10_16.3ds
        Will have a look.
          nnnnghn...... This beast has a zillion triangles...Su consumes 1.35GB atm.
          And the whole thing is slanted at an angle. Will take some work.
          Edges: 1514167
          Faces: 629920
          Components: 1971
            Simon B
            I'm still tidying up bordominc's version (thanks very much for that btw) - slow progress so far... so many reversed faces. Have tried to organise in C4D but with little success.
            • N Offline
              nightzombie
              wow i cant believe you managed to import the file into sketchup!!
              and its 1.35gb ๐Ÿ˜„
                WEll,.. I imporetd it with inches as units, (or was it feets...?) so the whole model was about 300mm long... made it look really odd since SU don't handle really small numbers very well. So I started a new file and tried to import with units set to meters, but then I got an out of memory error. Will try again today witha freshly booted PC.
                Mind you, it helps having 4GB RAM installed.
                  Tried to import with meter units... Out of memory. It built up to 1.7GB, then fell down to 400MB where it started buil.ding up again til 700MB where it ran out of memory.
                  I'll try with 3DS max first I think.
                  I belive the main problem is the terrain here. it got a very high subdivision and lots of detail. I want to try to remove the terrain and import without it.
                    Charlyboy
                    Someone has got the manhattan sketchup file with the 6.4.112 version plz??? I can't open it..(7.0 version is required) ๐Ÿ˜ž
                      Simon B
                      If anyone could recommend a good hosting site (zero pop-ups and no pron links preferable) I would be grateful.
                        Simon B
                        Charlyboy, would it work for you if I uploaded a version 5 of the model, so you can load into 6.4.112?
                        I've completed the tidy up using this great workaround from Moderator Jim:
                        One technique I remember from here is to assign a shortcut to Reverse Faces, then select the PushPull tool because it does auto-select on hover. Then, hover the PushPull tool over each face and hit the shortcut key - it makes quick work of it.
                        I've retained 99% of the geometry and there is a bit of tri-tesselation left over but some style settings can alleviate these.
                        • just need to find to find a host site for the file...
                          Also that doesn't delete the file after a while (or when it hasn't been downloaded for a while).
                          • N Offline
                            nightzombie
                            http://manhattanairport.org/
                            manhattan airport project with this sketchup model! hahaha
                            • Chris FullmerC Offline
                              That site seem vaguely familiar, like there used to be something there.....I can't quite think of what it was though.
                              Seriously though, I'm sick to my stomach. I'm sorry to say it night zombie, but I hope your project crashes and burns. I'm currently under-educated about all the details of it, but that is my first gut reaction. I'm literally feeling a bit ill.
                              Chris
                              All my Plugins I've written
                              • P Offline
                                Pg09
                                It's a joke project imo.
                                  That would sure make me feel a lot better ๐Ÿ˜„
                                  • N Offline
                                    nightzombie
                                    wow so much hatred! i have nothing to do with this particular project.
                                    i just found it online and they seem to have used the model i posted ๐Ÿ˜„
                                    • P Offline
                                      Pg09
                                      No hate from me i just stated my opinion... ๐Ÿ˜„
                                      • david_hD Offline
                                        david_h
                                        Olmstead is rolling in his grave. . .with Laughter!!! ๐Ÿคฃ
                                        Seriously tho' it sure would help on the commute in from the Airport. Have you ever tried to come in from JFK or LaGuardia?? NIghtmare!!!
                                          Hehe Night Zombie, my mistake all around. That caught me completely off guard. I figured it was a project you had made the model for, and it was a serious project, etc. Clearly, I fell for it hook line and sinker.
                                          Chris
                                            mclancer
                                            Thanks bordominc, much better now.
                                            • 3 / 3
