    Manhattan sketchup model
    60 Posts 21 Posters 26.9k Views 21 Watching
    • N
      nightzombie
      wow i cant believe you managed to import the file into sketchup!!
      and its 1.35gb πŸ˜„
        WEll,.. I imporetd it with inches as units, (or was it feets...?) so the whole model was about 300mm long... made it look really odd since SU don't handle really small numbers very well. So I started a new file and tried to import with units set to meters, but then I got an out of memory error. Will try again today witha freshly booted PC.
        Mind you, it helps having 4GB RAM installed.
          Tried to import with meter units... Out of memory. It built up to 1.7GB, then fell down to 400MB where it started buil.ding up again til 700MB where it ran out of memory.
          I'll try with 3DS max first I think.
          I belive the main problem is the terrain here. it got a very high subdivision and lots of detail. I want to try to remove the terrain and import without it.
          • C
            Charlyboy
            Someone has got the manhattan sketchup file with the 6.4.112 version plz??? I can't open it..(7.0 version is required) 😞
              Simon B
              If anyone could recommend a good hosting site (zero pop-ups and no pron links preferable) I would be grateful.
                Simon B
                Charlyboy, would it work for you if I uploaded a version 5 of the model, so you can load into 6.4.112?
                I've completed the tidy up using this great workaround from Moderator Jim:
                One technique I remember from here is to assign a shortcut to Reverse Faces, then select the PushPull tool because it does auto-select on hover. Then, hover the PushPull tool over each face and hit the shortcut key - it makes quick work of it.
                I've retained 99% of the geometry and there is a bit of tri-tesselation left over but some style settings can alleviate these.
                • just need to find to find a host site for the file...
                • GaieusG
                  Also that doesn't delete the file after a while (or when it hasn't been downloaded for a while).
                  • N
                    nightzombie
                    http://manhattanairport.org/
                    manhattan airport project with this sketchup model! hahaha
                    • Chris FullmerC
                      That site seem vaguely familiar, like there used to be something there.....I can't quite think of what it was though.
                      Seriously though, I'm sick to my stomach. I'm sorry to say it night zombie, but I hope your project crashes and burns. I'm currently under-educated about all the details of it, but that is my first gut reaction. I'm literally feeling a bit ill.
                      • P
                        Pg09
                        It's a joke project imo.
                        • Chris FullmerC
                          That would sure make me feel a lot better πŸ˜„
                          • N
                            nightzombie
                            wow so much hatred! i have nothing to do with this particular project.
                            i just found it online and they seem to have used the model i posted πŸ˜„
                            • P
                              Pg09
                              No hate from me i just stated my opinion... πŸ˜„
                              • david_hD
                                david_h
                                Olmstead is rolling in his grave. . .with Laughter!!! 🀣
                                Seriously tho' it sure would help on the commute in from the Airport. Have you ever tried to come in from JFK or LaGuardia?? NIghtmare!!!
                                • Chris FullmerC
                                  Hehe Night Zombie, my mistake all around. That caught me completely off guard. I figured it was a project you had made the model for, and it was a serious project, etc. Clearly, I fell for it hook line and sinker.
                                    mclancer
                                    Thanks bordominc, much better now.
                                    • 3 / 3
