    [Plugin] Zorro2 (beta)
    314 Posts 154 Posters 388.4k Views 154 Watching
      dadwill
      I would like to download zorro 2 but my computer doesn't read the .rb extension. Do you have some instructions on how to install it.
      • massimoM Offline
        massimo Moderator
        No need to read anything. Simply download the .rb file at the bottom of the first post and put it in your Sketchup's plugin folder (C-->programs-->google etc.). You will find Zorro under Tools menu.
        However if you want to read a .rb file use, for example, NotePad.
          maritozo
          I'm doing it just as the tutorial says
          first "add section cut face"
          and the "slice model at section"
          but even though my model doesn't have any groups, when it is cutting "group #n (29 or 31 most of the times)" the sketch up crashes 😞
          i've got a deadline in college, really need this to work out!
          anyone can help?
          thanks!
          • majidM Offline
            majid
            is there any way (tips/tricks or other cut tool) that only cuts the front faces, and not back (and not visiable) faces? I strongly need that πŸ˜„ plz
              schneider
              @chimbalo said:
              After a few hours I figure it out how to fix the bug splat, I have a heavy model, every time that I started using the slice tool my model crashed up, I tryed exploding the model, chainging to newer sketch up, etc etc etc. At the end I took all the model and grouped up whith out the cuting plane, after I slice it, and was the solution for the problem, now it doesn't matter how heavy is the file, the plug in ,work fine. sorry for my bad english, I hope is useful for you.
              I had the same issue, did the same thing like you did, making one big group and the problem was solved πŸ˜„
              • O Offline
                osse
                thank's a lot!!
                just found this amazing plugin, i have to make a final presentation for my project and it has to be ready in 2 weeks!
                this just saved me 2 days of work!!!
                amazing plugin!
                • E Offline
                  evp234
                  can somebody please send me the link download the zorro.2.o plugin for mac?
                  thankyou vanessa
                    tsemrud
                    This forum came up when I was searching about bug splats related to exploding components. I found a solution to the bug splats I was getting with my own plugin and maybe it will help diagnose the problems people are having on this forum.
                    Assume the following component structure:
                    Component_A
                    Component_AA
                    Component_AB
                    Component_AC
                    I was exploding from the top down with a recursive function, so I would explode Component_A, using ComponentInstance.explode which returns an entities object containing what was the component before I exploded it. I would then loop through that entities object and continue exploding any component instances I found. When I'd try and explode the first child (Component_AA) I would bug splat.
                    I found that it had to do with an entities observer that I had at the model level (which was my only entities observer). Once I got rid of the observer my code started working fine; no more bug splats!
                    So maybe Zorro2 or some other plugin on the computer of people who are experiencing bug splats is using an Entities Observer.
                    Hopefully this helps someone out there and hopefully this was the right place to post this.
                      Maybe you must start a thread about that on the section Developpers' forum πŸ˜‰
                      • N Offline
                        nickdk
                        I have problems as well, I have managed to cut my model after exploding everything and then making one big group, then it does the slicing but it doesn't delete anything afterwards? it's like it only creates an intersect with model line at the section plane? 😞
                        • P Offline
                          pogo_2u
                          Hi there,
                          I am trying to download the Zorro2 software, however I am just getting a text edit file. Is it compatible with Macs?
                          thanks a bunch
                          • P Offline
                            pogo_2u
                            I am a mac user and I am trying to download Zorro2 for a building section. However when I open the download it's giving me a 'text edit' file. Which I can't save in my plug ins folder.
                            Help please!!
                            Thanks a bunch
                            • OxerO Offline
                              Oxer
                              Help please!!
                              Thanks a bunch
                              Hello!
                              I'm mac user too, generally when you download a ruby file (.rb extension) from Safari the program add .txt extension to the file, you must delete the .txt extension to the file and to leave the filename so: Zorro2.rb
                              Example: *******.rb.txt (delete the last extension .txt) >> ********.rb
                              Then, place the Zorro2.rb in your plugins folder of SU, perhaps OSX ask you for permissions to copy the file in the plugins folder, enter your user password and OK.
                              I hope that help you, Bye!
                              http://www.oxervision.blogspot.com/
                              • P Offline
                                pogo_2u
                                When I click to download it, it is opening in text edit, so I re-save to my plugins folder with the .rb extension and it isn't showing up. Should I be saving differently? I really can't figure out what I'm doing wrong.
                                Thanks for your help so far!
                                Hello!
                                I hope that help you, Bye![/quote]
                                • K Offline
                                  kwalkerman
                                  Awesome plugin. Works great with the section plane and with the straight zorro tool.
                                  I was getting bugsplats when I used the section plane (on very simple models). De-activated another plugin (openstudio), and now it works fine.
                                  Karen
                                  • P Offline
                                    Ph33r1es5
                                    Kool, this will help me get a good section for my assignment πŸ˜„
                                      Karen
                                      Also when using any tool that changes the models entities with instances you need the Outliner to be closed or at least rolled-up - otherwise a known bug in SUp can cause it to crash...
                                      • DavidBoulderD Offline
                                        DavidBoulder
                                        TIG, is this working on SU 8? I'm getting crashes on XP without any other plugins installed.
                                        David Goldwasser
                                        OpenStudio Developer
                                          Works OK for me with the Outliner closed ?
                                            DavidBoulder
                                            No dialogs open (including Outliner). I even tried disabling Dynamic Components, Sandbox Tools, Solar North, and Photo Textures.
                                            I'll try again tomorrow after a fresh restart. By the way, same results on SU7.
                                            Split at section cut seems to work. Just cut tool that crashes.
                                            David Goldwasser
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 15
                                            • 16
                                            • 7 / 16
