    Getting file paths in SU 7
    9 Posts 6 Posters 695 Views 6 Watching
    • Al HartA Offline
      Al Hart
      Did the result of:
      mydir = File.dirname(__FILE__)
      change for SU 7 (and/or Vista)?
      If so, how are people getting the location of a .rb file?
      Al Hart
      IRender nXt from Render Plus
        I was wondering that myself... I thought I'd used that before, but when I wanted to get the plugin directory recently it didn't seem to work.
          Jim
          It works for me in SU7 & XP - what is the value of FILE?
          puts __FILE__
          C;/Program Files/Google/Google SketchUp 7/Plugins/tmp/file.rb
          I know it barfs when the file is encrypted.
            puts __FILE__
            (eval)
            nil
            SU7 on Windows7.
              I'm such a numpty! I tested it in the Ruby Console... 😳
              Just please ignore everything I've said in this thread.
                avariant
                Since that is a ruby constant, or whatever, not an SU specific thing, I wouldn't have expected it to change. I don't think the version of ruby is different between XP and Vista (1.8.6 right?).
                Here are a couple alternatives I found around
                File.expand_path(__FILE__+'/..')
                File.dirname(File.expand_path(__FILE__))
                  azuby
                  Sketchup 7 uses Ruby 1.8.0 like Sketchup 6 does. Type VERSION to see the version number into the Ruby Console.
                  azuby
                  • Al HartA Offline
                    Al Hart
                    Thanks to all for helping me look into this. (The .rps barf comment provided the clue)
                    I found the problem. We are using a ruby '<<' construction to turn the whole source of a .rb file into a string, and then execute it with TOPLEVEL_BINDING. This makes the error messages and trace messages report the proper file and line numbers with .rbs files.
                    However, we were passing the eval() function the basename of the file rather than the full path name.
                    For other programmers using .rbs files, who want error paths reported properly, here is the code to place around the contents of your .rb file.
                    printf("***** Loading; %s\n",File.basename(__FILE__))
                    start_line = 3 # set to current line
                    sexec_string = <<-'END_FILE'
                    [... contents of ruby source file ...]
                    END_FILE
                    #load the file with proper binding, name, etc.
                    begin
                    	eval(sexec_string, TOPLEVEL_BINDING, __FILE__, start_line+2) # add 2 to start_line
                    rescue Exception => $emess
                    	printf("ERROR loading; %s\n\t%s\n\tin; %s\n", __FILE__, $emess.message,$emess.backtrace[0])
                    Al Hart
                      RickW
                      We've asked Google to fix this, but no dice yet.
                      Ditto on Ruby access to Dimension objects.
                      RickW
                      www.smustard.com
