    30 Watt Fishbulb
    32 Posts 11 Posters 3.3k Views 11 Watching
    • P Offline
      princedragoncok
      Inspired by my goldfish. Setup in sketchup. Lightbulb and fish from the 3d warehouse. Rendered in Hypershot
      Update - smoother bulb with added light intensity.
      http://i346.photobucket.com/albums/p420/princedragoncok/fishbulbnew3.jpg
      http://i346.photobucket.com/albums/p420/princedragoncok/fishbulb8-1.jpg
        bubbalove
        Neat concept! Could be smoother though...
        "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
        • EarthMoverE Offline
          EarthMover
          PDC - Neat idea. Increase the number of bounces to get rid of some of the artifacts you see.
          Content Creator at Skapeup
            ScottPara
            Cool concept but if you are going to have the lightbulb as the main focal point then a high poly lightbulb is a must.
            Scott
            Love the fact that some HATE my avatar.....
            • soloS Offline
              solo
              That's pretty cool and I must agree getting a higher polygon bulb will help, maybe just apply one iriteration of SDS to smooth it.
              http://www.solos-art.com
              • P Offline
                princedragoncok
                Yeah I agree everyone. The bounces were already set at their highest, shadow quality not though. I tried 1 iriteration and in fact it worked the first time but I got greedy and went for 2 and messed things up. Now 1 doesn't seem work anymore (at least with regard to texture preservation).. will try again. Thanks for the feedback!
                • soloS Offline
                  solo
                  Hope you do not mind, I liked the idea so much that I thought I'd give it a go too.
                  I used Vue for the render.
                  http://img207.imageshack.us/img207/2756/fishbulbwc4.jpg
                    If you plug the bulb in, an easy way tocook a fish soup... πŸ˜‰
                    • E Offline
                      ENG. YASEEN
                      **It's amazing idea and work ،In particular the 2th photo
                      thank's**
                      My Website:
                      http://xyz4studio.blogspot.com/
                      • P Offline
                        princedragoncok
                        Not at all, v nice. Your fishbulb appears to be a lot more robust than mine! I have to say i'm interested in trying out vue. So a few quick questions for the vue master: whats the learning curve like? and which package would you reccommend (as there seems to be loads). Thanks
                          EarthMover
                          I think both renders would serve well with a touch of caustics reflection on the ground as the light passes through the water in the bulb.
                            Click Draw
                            Very nice renders both. When rendering, do you set the glass material to 0% opacity and reflection to 100%?
                            Jeff
                            Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                            • P Offline
                              princedragoncok
                              Totally agree, but I don't think I have that option with Hypershot? correct me if I'm wrong
                              As far as I know, v-ray is the only renderer supporting caustics at the moment.
                              Jeff
                              Well with hypershot its simply a matter of applying a default glass material that comes with the program. If I was to make glass with Podium however I'd probably make a translucent material, set it to 10-15% opacity, and 85-90% reflection.
                                Click Draw
                                Well....I finally bit the bullet. I just bought VRay for SU. I'm feeling a bit sick all of a sudden. I better take next week off from work ...LOL.
                                Jeff
                                • P Offline
                                  princedragoncok
                                  Jeff
                                  Nah your going have to work overtime now! V-ray is the benchmark so definitely not a bad investment. Learning curve is a bit horrible though, so brace yourself for a stressful first few renders. Hmm I'd actually like to try this current render out with v-ray.. or maybe let someone else do it - how about you clickdraw?
                                    Click Draw
                                    Sure PDC,
                                    I'll give it a go for sure. I'm just waiting for my activation code via e-mail but once I have it I'm in! Post your model for me or PM me. Thanks for the chance πŸ˜„ .
                                    Jeff
                                    • soloS Offline
                                      solo
                                      Jeff a Vray render of this would be great, nice one to sharpen your teeth on.
                                      Vue does caustics too, I chose not to have them as they complicated the scene to much (looked very busy)
                                      Vue's learning curve is hard to assess, I learned it so long ago, on version 4, it was easy as I only used it to create terrains for use in Max, and over time I started to learn it without trying to learn it. Vue is pretty straight forward really, the only difficult part is the node based functions IMO.
                                      • P Offline
                                        princedragoncok
                                        Cheers for the info solo. The scene is available to everyone to download for seven days.
                                        https://www.yousendit.com/download/WnBSVWRqTStoMlVLSkE9PQ
                                          EarthMover
                                          Hey prince
                                          Thanks for sharing the model. I ran the bulb through SDS with 1 iteration and then gave it a go with hypershot. Render took about 3 min.
                                          • soloS Offline
                                            solo
                                            Vue again.
                                            http://img294.imageshack.us/img294/5427/fishbulbrg0.jpg
                                            added a 'green' one too.
                                            http://img172.imageshack.us/img172/172/flourescentvuese3.jpg
                                            • 1 / 2
