    How to close this curve??
    5 Posts 5 Posters 701 Views 5 Watching
    • 3 Offline
      3eighty
      Can somebody tell me how to close the face of the left curve...I need to do this on all 4 corners and since p/pull will not do curves, Looking for an easy way...
      • E Offline
        ethip
        Just draw a line from each corresponding end point of the curve and then hide the edges.
        ethip
        • Chris FullmerC Offline
          How do you mean that push/pull won't do curves? You should be able to pull up that face just fine.
          Chris
          All my Plugins I've written
            remus
            Any reason you cant just do as chris suggested?
            p.s. if you do have to stitch it closed, your better of smoothing the lines rather than hiding them.
              sepo
              You should be able to pushpull that surface or otherwise use extrude lines ruby.
