How to close this curve??
Can somebody tell me how to close the face of the left curve...I need to do this on all 4 corners and since p/pull will not do curves, Looking for an easy way...
Just draw a line from each corresponding end point of the curve and then hide the edges.
ethip
How do you mean that push/pull won't do curves? You should be able to pull up that face just fine.
Any reason you cant just do as chris suggested?
p.s. if you do have to stitch it closed, your better of smoothing the lines rather than hiding them.
You should be able to pushpull that surface or otherwise use extrude lines ruby.
