    [Plugin] 1001bit Tools - Architectural tools for SketchUp
    245 Posts 66 Posters 263.1k Views 66 Watching
    • G Offline
      gohch
      Hi everyone,
      1001bit tools is now possible for different languages! πŸ˜„
      A new language pack function is added into version 1.1.5, which allows for automatic translation of the dialog boxes, status bar, tooltips and error messages into your local languages.
      http://www.1001bit.com/language_pack/v1.1/images/dialog-cn.jpg
      hip roof dialog in Chinese Simplified - courtesy of purplewind
      http://www.1001bit.com/language_pack/v1.1/images/dialog-jp.jpg
      hip roof dialog in Japanese - courtesy of Takeshi
      Here's how it works
      In version 1.1.5, there's an additional language folder inside the 1001bit folder.
      http://www.1001bit.com/language_pack/v1.1/images/language_folder.jpg
      inside the language folder, there's a collection of text files (.txt) which contains the language translation.
      http://www.1001bit.com/language_pack/v1.1/images/sample_cn.gif
      translation courtesy of purplewind
      The format of the translation is
      id>>english>>translation
      Just use a text editor to edit the .txt file and save it.
      You may need to try saving the file in different format, for example, the Chinese version has to be saved in UTF-8 format for it to work properly on a Mac (English).
      The first full translation into Chinese Simplified language has been completed and tested by purplewind of club.sketchupbar.com
      http://www.1001bit.com/discussions/viewforum.php?f=17
      Special thanks to Purplewind for his hardwork!
      by the way, the 1001bit_tools.rbs file in the Plugins folder needs to be replaced with the latest. Otherwise you'll see a lot of errors!
      • G Offline
        gohch
        hi guys,
        I have modified the 1001bit_tools.rb to automatically look for the files in SU's Plugins/1001bit folder regardless of Windows or Mac.
        if it cannot find the files, it then search for c:\1001bit.com
        So, the setting up can be simplified to
        Step 1: put the 1001bit folder in SU's Plugins folder
        Step 2: copy the 1001bit_tools.rb file into the Plugins folder
        Appreciate if you guys can test this for me:
        Attached zip file contains 2 files,
        1001bitmenu.rbs file
        1001bit_tools.rb
        1. Please overwrite the 1001bitmenu.rbs file (must be version 1.1.5)
        2. remove the 1001bit_tools.rbs file , and use the 1001bit_tools.rb in your Plugins folder instead.
        3. remove any file that indicates the path, like 1001bit_path_.....rb
        In this case, the 1001bit folder must be in your Plugins folder.
        Thanks and appreciate all feedbacks
        patch for testing 1001bit default path
          I advanced the French version! β˜€
          Tell you when it's finished πŸ˜‰
          • G Offline
            gohch
            Great Pilou,
            really looking forward to see 1001bit in more different languages! πŸŽ‰
              @GOHCH
              French translation done β˜€
              See your PM system at PushPullbar πŸ˜‰
              See your forum for images & questions πŸ˜„
              • G Offline
                gohch
                hi Pilou,
                Thanks so much for your efforts!
                1. Tooltip text: Seems like there is a maximum of 79 characters in the tooltip. I couldn't get it to do more, and couldn't get it to do multi lines of text.
                  Has anyone come across a tooltip with multi lines of text?
                2. The Escalator title: tracked down the problem. It's that little Apostrophe (')
                  title>>Create Escalator>>CrΓ©ation d'Escalator
                  when Javascript sees a apostrophe('), it interprets as the beginning of another string and caused an error.
                  The translator defaults back to English when there's an error getting the translation.
                  Adding a back slash in front of it will get it to be interpreted correctly.
                escalator title translated correctly with
                cheers!
                Goh
                  OK! So some modify to make πŸ˜„
                    @GOHCH
                    See your forum for little problems πŸ˜‰
                    • Z Offline
                      zfconnor
                      Thank you for your effort.
                      • P Offline
                        publied
                        very nice library! great job.
                        hire me@ http://www.publied.it !
                        • G Offline
                          gohch
                          😍 Thanks to Frenchy Pilou's hardwork, 😍
                          the French language pack for 1001bit tools is now ready for download!
                          http://www.1001bit.com/language_pack/v1.1/fr/1001bit_v1.1_language_fr_pilou.zip
                          Some of the dialog boxes may be insufficiently sized to accomodate all the French languages. Please bear with this for another 2-3 weeks. I'll issue a version 1.1.6 update soon that addresses resizing of dialog boxes as well as installation path automatic settings.
                          Again, Thanks Frenchy Pilou
                            πŸ˜„ πŸ˜‰ β˜€ 😎
                            • P Offline
                              putnik
                              GOHCH, 1001bit_patch(3-May-09).zip works fine for me. WinXP SP3. Russian language translation is a work in progress at the moment at stroyka.cc
                              http://keshas.info
                              • G Offline
                                gohch
                                Thanks Putnik, for testing out the patch. πŸ˜„
                                I'm really excited πŸŽ‰ to see someone doing a Russian language pack.
                                I've placed a link on 1001bit.com pointing to Stroyka forum for anyone who is interested in the Russian language pack.
                                http://www.1001bit.com/discussions/viewtopic.php?f=17&t=52
                                Thanks!
                                • G Offline
                                  gohch
                                  hi guys!
                                  Thanks to Oxer, there is now a Spanish language pack!!!
                                  http://www.1001bit.com/discussions/viewtopic.php?f=17&t=54
                                  Thank you Oxer for sharing your hardwork! πŸ‘
                                  • F Offline
                                    fozmicro
                                    Hello!!!!
                                    I think interesting a portuguese (br) translation pack
                                    • BurkhardB Offline
                                      Burkhard
                                      German language ready, including image changes. Should come soon πŸ˜„
                                      Have fun
                                      [http://www.ia-plus.de(http://www.ia-plus.de)]
                                      • G Offline
                                        gohch
                                        Hi guys, 2 more language packs ready for download!!!
                                        Spanish language pack, thanks to Oxer's hardwork πŸ‘ πŸ‘ πŸ‘
                                        German language pack, thanks to Burkhard's hardwork πŸ‘ πŸ‘ πŸ‘
                                        http://www.1001bit.com/discussions/viewtopic.php?f=17&t=55
                                        And... Portugues language pack coming soon... courtesy of fozmicro. πŸ‘ πŸ‘ πŸ‘
                                        It's really encouraging for me to see different people translating 1001bit tools into different languages.
                                        Many many thanks to everyone's hardwork and support!!!
                                        GohCH
                                        • F Offline
                                          fozmicro
                                          20% complete translation from portugues (br).
                                          πŸ€“
                                            New version with this crazzy Plugin πŸ˜‰ See details here
                                            http://www.1001bit.com/forum_imgs/revsurf-1.gif
                                            This tool produce a revolved surface from selected edges, and the edges do not have to be co-planar.
                                            You can specify the angle, segments along the rotation, and also the scale.
                                            http://www.1001bit.com/forum_imgs/revsurf-2.gif
                                            http://www.1001bit.com/forum_imgs/revsurf-3.gif
                                            • 6
                                            • 7
                                            • 8
                                            • 12
                                            • 13
                                            • 6 / 13
