    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    Random Push Pull by Tig
    11 Posts 6 Posters 14.9k Views 6 Watching
      Seems nothing works? โ“
      Is there a special installation โ“ (i have the sketchup.rb)
      I select some faces of some objects(not grouped) but nothing... ๐Ÿ˜ฎ
      Unity must be in inch? (I am in cm)
      rand.skp
      • Chris FullmerC Offline
        Bummer, its not working for me either. It would be handy right now... ๐Ÿ˜„
        Chris
        All my Plugins I've written
          Jim
          Change this line (38) from this
          	ss[i].pushpull ht.in ### into inches ***
          to this.
          	ss[i].pushpull ht.inch ### into inches ***
          Just a typo..
            Cools that works with your modification! โ˜€
            Have you a little trick for select only "surfaces"?
              Jim
              This will ignore selected edges.
              edit - and work in the current model units, whatever they are.
              edit - download removed. see TIG's updated plugin.
                Bravo! ๐Ÿ‘
                Now that is absolutly rocking! ๐Ÿ˜Ž
                  Excellent. I'll have to play with this now. I've been learning ruby and greeble was the firs thing on my list. I'll check this script out now to understand how it works, then maybe I'll try to modify it to be more greebley ๐Ÿ˜„
                  Anyhow, thanks for script TIG and thanks for the tweaks Jim,
                  Chris
                  • dereiD Offline
                    derei
                    It seems to be a problem with the plugin.
                    It doesn't respect the max/min values at all ๐Ÿ˜ž
                    See the images.
                    DESIGNER AND ARTIST DEREI.UK
                      See the images.
                      Did you use TIGs original script, or Jims modified version ( http://forums.sketchucation.com/viewtopic.php?f=180&t=15824#p123151 ) ?
                      • dereiD Offline
                        derei
                        See the images.
                        I gues Jim's ๐Ÿ˜• I downloaded it from here (see up)
                        Where I can find TIG's script?
                          Here's a new v2.0 that tidies it up a bit... http://forums.sketchucation.com/viewtopic.php?p=340452#p340452
