    [Plugin] Cloud (update)
    9 Posts 8 Posters 13.4k Views 8 Watching
    • Didier BurD Offline
      Didier Bur
      Below is an update of my script to import 3D "points cloud".
      It now skips blank lines, wrong lines (not returning 3 valid coordinates) and invalid data (non-digit data).
      Enjoy,
      Put cloud.rb in your Plugins folder, read the PDF's, follow the quick tutorials, and report bugs !
      DB
        Cool update, thanks! Spares a lot of manual editing of messy data files. 👍
          sepo
          Thanks very much.
          • MALAISEM Offline
            MALAISE
            MALAISE
            • I Offline
              ilay7k
              Didier, thank you!
                Matt
                Dear Didier,
                Just wanted to say thank you so much for your revised script - I had the same problem described - but your enhanced '09 version solves it and is much improved - the auto line drawing is particularly good. I'm using your script to allow me to work with complex geometry within Sketch-up which I've calculated within Excel.
                Sterling work old chap!
                Matt 👍
                  SAnderka
                  Thanks for the update!
                  Also, this observation might help people with unexplainable "nothing happens"-errors:
                  http://forums.sketchucation.com/viewtopic.php?f=323&t=1537&p=223655#p223655
                    cj4195
                    Hi I am currently trying to open point cloud data using this plug-in, however, the data I am using is in .ptsb format which will not work, any ideas how I can convert it to .csv?
                      Didier Bur
                      No need to convert it to CSV.
                      Here is what Autode$k says about ptsb format:
                      Pointcount
                      X Y Z Intensity R G B
                      (Intensity is a float value 0-1)
                      Example:
                      0 0 0 .5 128 128 128
                      1 1 0 .5 128 128 128
                      Quite simple isn't it 😄
                      So open your file in a text editor, erase first line (number of points), save it to 'somefilename.txt' and it should work. Just set the points cloud reader first dialog to use a space delimiter, and second dialog to set X,Y,and Z coordinates as the first, second and third datum of each line (see below).
                      I've tried this example and it works.
                      Dialog 1
                      Dialog 2
                      Regards,
                      DB
