    How do I reset the axis of the DC Marvin window component?
    6 Posts 4 Posters 886 Views 4 Watching
      make
      It snaps to about an inch outside the wall I place it in. That's fine for frame construction but I want to inset it as I am putting in a masonry [corrected] wall.
      Any ideas?
      Cheers!
      • N Offline
        neoshed
        I would have thought if you double click on the component you would see where the axis location is and you could move the parts so the point that is correct?
          Jim
          make,
          open the Component Browser dialog, right-click on the component and select the Reset Insert Point option from the pop-up menu.
            make
            Thanks, I'll try it.
            Next, how do I get the wall opening on the inside without having to draw it? Or do I just have to draw every single one?
            Thanks!!!!
            • N Offline
              neoshed
              Unless sketchup change in v7 it never cuts the opening on the inside
                No,it hasn't changed. A component can only have one gluing/cutting plane at a time (since the axis szstem defines it and there can only be one axis system at a time). There are workarounds but not an ultimate solution.
