    Newbie texture question
    6 Posts 3 Posters 656 Views 3 Watching
    • N Offline
      nightzombie
      hi
      i'm trying to apply a wooden kerkythea texture to a subdivided shape that i made
      and the result is texture applied to each triangulated faces of the geometry.
      is there a way to smooth out the textures?
      http://i545.photobucket.com/albums/hh366/nookie8532/violin_modeling.jpg
        Hi Nightzombie and welcome (nice name BTW πŸ˜‰ )
        I see that you already have hidden geometry turned on. Now right click on any of the facets, go to Texture > Position and do nothing just hit Enter.
        Now with the Paint bucket tool activated, press and hold the Alt key (the Paint tool will turn into an eyedropper / sampler) and click on the same facet you positioned the texture on.
        Now turn off hidden geometry and paint your surface. Note however that if it curves in several directions,you may still have some minor problems.
        • N Offline
          nightzombie
          wow thank you!
          that was super fast
            And how does it look like now?
            • N Offline
              nookie8532
              well, i did as you suggested
              and it didnt turn out the way i expected
              i cleaned up the geometry after remus' crit from
              gallery forum.
              http://i545.photobucket.com/albums/hh366/nookie8532/texturetest.jpg
              here is picture of when i first applied the wood texture
              http://i545.photobucket.com/albums/hh366/nookie8532/texturetest2.jpg
              and here is the texture applied like you said
              http://i545.photobucket.com/albums/hh366/nookie8532/texturetest3.jpg
                Then instead of positioning, select the "Projected" option instead.
