    Profile Builder released!
    125 Posts 41 Posters 60.9k Views 41 Watching
      seasdes
      Thanks for the plugin. Can I explain to a simpleton how I can have the walls intersect and mitre correctly when the the walls are created separately.
      Walter
      Using Sketchup Pro 2019
      • utilerU Offline
        utiler
        Thanks Dale, I'm having heaps of fun with this....
        One questions: when creating a closed profile member, picking the point where you started doesn;t merge the profile. [see attached] I understand I could do it 'building along a predefined path' but seems it appears to be the long way around....
        Thanks in advance.
        Just Curious...
        • utilerU Offline
          utiler
          Another few things:
          1. the "build" icon sit right over the cursor which makes it difficult to snap to points... in your video you used the standard cursor which was a little easier, can you look at this?
          2. the X and Y offset values don't seem to be saved with the profile. I think this is imperative that they are. When you chose another library and or profile the offset values stay the same as the previous profile which means working it out for each one. For simple profiles, sure it's easy but complex profiles this is very tedious....
          3. Can you set 'exit' the fuction of a profile member to be "right button" as with all other SU functions rather than "Esc"? Would make for more streamlined use...
          Anyone else please let me know if you find it difficult to use....
          Just Curious...
          • plot-parisP Offline
            plot-paris
            use right mouse button to exit a function in SketchUP? I always get the context menu if I try that.
            sure you are not talking about Rhino? πŸ˜•
            • H Offline
              haynesc
              I have a problem ... 😞
              why is the profile at an angle ?
              • W Offline
                Whaat
                Strange...this should not occur if the profile was created from the face that is shown in your screenshot. Is it possible that you modified your axis?? Right click on the axis and choose reset. Then, try to make the profile again.
                Is this problem repeatable?
                • P Offline
                  peweuk
                  I just replicated what you appear to show in your image, and this is the result
                  Maybe there is something different about the angle that the face used to create the profile was created relative to the X and Y axis?
                  Make sure the face sides are parallel to the X, Y axis before your select the option to make the profile.
                  • W Offline
                    Whaat
                    Thanks in advance.
                    Refer to the troubleshooting section of the manual. My only suggestion is to try using a bottom-left or bottom-right placement point with no offset. I know that this might not be the ideal location of the origin but in some cases, it is the only way to create a closed loop. I am meaning to report this as a possible SketchUp bug because this occurs far less frequent when using the standard follow-me tool, even though Profile Builder uses the follow-me method from the SketchUp API. πŸ˜•
                    • W Offline
                      Whaat
                      Thanks in advance.
                      Refer to the troubleshooting section of the manual. My only suggestion is to try using a bottom-left or bottom-right placement point with no offset. I know that this might not be the ideal location of the origin but in some cases, it is the only way to create a closed loop (i.e. placement point at corner of profile). I am meaning to report this as a possible SketchUp bug because this occurs far less frequent when using the standard follow-me tool, even though Profile Builder uses the follow-me method from the SketchUp API. πŸ˜•
                      • W Offline
                        Whaat
                        Walter
                        If you have two walls that are in separate groups and you want to intersect or mitre them, you could try doing a 'union' operation with BoolTools http://www.smustard.com/script/BoolTools.
                        I am not sure how else to do it (there is no function in ProfileBuilder do this). Maybe someone else could suggest an alternative method...
                        • W Offline
                          Whaat
                          1. When you assign Mark numbers - ie a Prefix or Suffix eg #1,
                            I was expecting the original Group Name to still remain - is this deliberate or a bug ???
                            eg Original Group Name = UB_152x89x16
                            After applying Mark (Suffix) I would expect to see:
                            UB_152x89x16#1, UB_152x89x16#2, UB_152x89x16#3 etc
                            What I get is #1, #2, #3 etc
                            Could you please take a look at this if you get time as this feature will be so useful.
                            (Make original group name remain by default - unless users actually DO want to get rid of it).
                          Check the manual. To keep the profile name in the group name, use '$P' in the suffix or prefix.
                          1. Something for you to ponder:
                            I have folders containing many profiles. One skp file = One Profile. I'm sure I'm not alone.
                            (eg Steel Sections).
                            Traditionally, this would be imported into a skp file (it would now be a component) and then extruded manually. Profile Builder gives us the ability to do our extruding a bit smarter and quicker than this - Halleluljah !!!.
                          My request is, could you either:
                          a. Add in a feature to import profiles from a directory THAT ARE INDIVIDUAL *.skp files into a Profile Library (profiles retaining their skp filenames minus the *.skp file extension ie UB_123_567.skp = UB_123_567 in profile library OR
                          b. A feature so that these profiles can be utilised directly (ie without importing them).
                          Do you know that I have steel section libraries already created and ready for download on the Smustard website? As for your suggestion, it is a good idea for the next version. I will consider it. Thanks!
                          BTW, I intend to create more free downloadable profile libraries based on user requests. There are also ways to create to Profile Libraries from an Excel spreadsheet. I hope to create a tutorial for this someday. If you take a look at the file format for the PLB files, you can probably figure it out. The format is 'NAME x1 y1 x2 y2 x3 y3 ....'
                          • david_hD Offline
                            david_h
                            Thanks Whaat. I am sure there is a Knighthood in this for you.
                            πŸ’š
                            David
                              dtrarch
                              Dale
                              You said
                              BTW, I intend to create more free downloadable profile libraries based on user requests. There are also ways to create to Profile Libraries from an Excel spreadsheet. I hope to create a tutorial for this someday. If you take a look at the file format for the PLB files, you can probably figure it out. The format is 'NAME x1 y1 x2 y2 x3 y3 ....'<
                              Please explain how to format for spread sheet (CSV ?) and also how to convert the spread sheet to a vector graphic of each profile.
                              We all would like to share libraries and just need a little help to set them up and edit outside of PB.
                              Thank you
                              dtr
                              • H Offline
                                haynesc
                                problem fixed, my axis were incorrect ...
                                • utilerU Offline
                                  utiler
                                  @utiler said:
                                  Another few things:
                                  Dale, any comment on these issues...?
                                  Just Curious...
                                  • utilerU Offline
                                    utiler
                                    Just wondering if you guys see this suggestion for enhancing PB worthwhile:
                                    1. I'd like to see Profiles not just be restricted to faces but also 'profiles' as well. Not all modeling needs a thickness [eg: wall and roof sheeting / purlins / gutters] Would be great to be able to create a profile out of a polyline and build a path, pre-defined or as you go...
                                    Also, a thinking a little beyond PB. Dale has obviously bought us some scripts of late that are like no other; they're more 'activities' rather than functions within SU. I think Dale is not far from bringing us a complete set of 'activities' specific to individual industries. Eg: I'm in the architectural field; I'd like to see building components targeted such as windows, doors, stairs and roofs. As we all know we are yet to work out how to cut two planes with SU to make windows and doors easy to handle. It seems if Dale's Booltools were integrated with a script to create windows and doors, we shouldn't be far from getting it right!!!
                                    These additions along with TIG's "roof" script would almost complete SU for me. What are your thoughts?
                                    Just Curious...
                                    • david_hD Offline
                                      david_h
                                      I tried to use a profile to make a picture frame and it wouldn't close (miter) properly at the end as it would do with just the normal follow-me? What am I doing wrong?
                                      David
                                      • utilerU Offline
                                        utiler
                                        David, try setting the offset to zero and starting from the bottom left or bottom right location. I found this to happen also but seems to close only when using these placement points....which renders the offset options a little useless really. πŸ˜•
                                        Just Curious...
                                        • K Offline
                                          kagrani
                                          I had the same problem when I started playing with PB yesterday, but I think I stumbled upon a fix: just continue the path around/past the 4th corner as well, and it will miter correctly. And I couldn't find excessive geometry afterwards.
                                          Can anyone confirm?
                                          Knut
                                            plot-paris
                                            I think that is because PB relies on SketchUp functions to draw the members. so the actual problem doesn't lie with ProfileBuilder, but with SketchUp. it works indeed better, if the offset is set to one corner of the profile (can be quite difficult to determine, when you have a complicated profile, of course).
                                            but I think Whaat has covered all this in his superb manual πŸ˜‰
                                            • 6
                                            • 7
                                            • 2 / 7
