    [Plugin] V-Ray Tools
    238 Posts 80 Posters 268.7k Views 80 Watching
      Could it be... there are some files in your VirtualStore?
      This utility might help you check: http://sketchucation.com/forums/viewtopic.php?f=180&t=48399
        dtrarch
        TT
        I have BU SSD for boot and apps.
        Something on my current disk is just sideways.
        The script runs perfectly on the BU drive.
        Sorry to cause all the fuss.
        Just a case of computer hell.
        Thanks for all your good natured help πŸ‘ πŸ‘
        Dave
          Glad it works - somehow. :s
          Did you check the VirtualStore?
          • P Offline
            penumbra
            Thomas
            I get the attached error after install. any thoughts?
              dtrarch
              TT
              Yes I did run the Virtual Store and error still there.
              Could be a root kit or such but OK now.
              Thx πŸ‘
              dtr
              • P Offline
                penumbra
                TT
                never mind about my issue. deleting the old TTLib and tantalizing the new one seem to get rid of the issue.
                Omar
                  Milunice259
                  I have the same error like him. Anybody help!!
                    Very little I can do without any further info.
                    And as you can see in the previous post, penumbra solved it by uninstalling TT_Lib2 and then installing it again.
                    • P Offline
                      penumbra
                      of course rather than "tantalising" the old one I "uninstalled" the old one.
                      • H Offline
                        harinama
                        dude, i owe you a sixpack, if you're ever in Seattle...!
                        Such a simple thing, to load or not load a plugin at SU startup, yet took hours of searching to find this tool. Works great, and solves a huge problem my labs are/were having with vray network licensing.
                        Thankyou,
                        Harinama
                          πŸ˜„
                          puts a beer mark on Seattle
                          • broomstickB Offline
                            broomstick
                            This new version is looking very good!
                            I still have problems with camera match, though. Even after regenerating a Camera Matched scene, rendering in vray produces an image as if the camera has zoomed in on the object.
                            I can't publish any image now, to show the problem, but I will try to do it later, so you can see what happens.
                            Take care,
                            Michael
                              broomstick
                              I had a little time to do a simple photomatch:
                              this is the photomatch scene:
                              http://www.3dita.it/plugins/vraytools/scena1.JPG
                              This is the recreated scene:
                              http://www.3dita.it/plugins/vraytools/scena2.JPG
                              This is what Vray comes up with:
                              http://www.3dita.it/plugins/vraytools/scena3.JPG
                              Any advice?
                                Is the V-Ray camera set to zoom?
                                  broomstick
                                  The zoom value of the Vray camera is set to 1,0
                                  Do I have to look somewhere else?
                                  • P Offline
                                    penumbra
                                    TT,
                                    Thanks for the awesomeness, this one is a beauty. Put another beer on the map if in Baltimore.
                                    I am experiencing some odd behavior, perhaps others are also. I have a simple studio scene set up. After running the plugin and applying aspect ratio I see the familiar safe frame bars on either side of the viewport just fine. If I orbit around the scene and then try to return the scene to its view point by hitting the scene tab, the bars disappear. The only way I can get them back is by clicking off the TT vray camera tools and then running the script again. not a big deal but wish it weren't so. Any thoughts?
                                    Attached are some pics if it helps.
                                    My office still runs version 1.48 on Windows 7 64 bit machine.
                                    Omar
                                    Desired Setup
                                    Orbiting around
                                    return to scene, bars gone
                                      Not sure what it is. But I've had some issues occationally myself. Trouble is that SU doesn't expose everything. Might be that.
                                      After you set the aspect ratio you need to Update the scene. (Right-click Scene Tab > Update)
                                      • P Offline
                                        penumbra
                                        TT
                                        Thanks, sure enough that did the trick. Now i am embarrassed.
                                        O
                                          broomstick
                                          Thanks for taking the time to follow me through. Let's hope a new version of VfSU is on its way soon!
                                          • SupumanS Offline
                                            Supuman
                                            Thanks!!!very useful!!!
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 8 / 12
