    [Plugin] V-Ray Tools
    238 Posts 80 Posters 295.0k Views 80 Watching
      penumbra
      Thomas
      I get the attached error after install. any thoughts?
        dtrarch
        TT
        Yes I did run the Virtual Store and error still there.
        Could be a root kit or such but OK now.
        Thx πŸ‘
        dtr
          penumbra
          TT
          never mind about my issue. deleting the old TTLib and tantalizing the new one seem to get rid of the issue.
          Omar
            Milunice259
            I have the same error like him. Anybody help!!
              Very little I can do without any further info.
              And as you can see in the previous post, penumbra solved it by uninstalling TT_Lib2 and then installing it again.
                penumbra
                of course rather than "tantalising" the old one I "uninstalled" the old one.
                • H Offline
                  harinama
                  dude, i owe you a sixpack, if you're ever in Seattle...!
                  Such a simple thing, to load or not load a plugin at SU startup, yet took hours of searching to find this tool. Works great, and solves a huge problem my labs are/were having with vray network licensing.
                  Thankyou,
                  Harinama
                    πŸ˜„
                    puts a beer mark on Seattle
                    • broomstickB Offline
                      broomstick
                      This new version is looking very good!
                      I still have problems with camera match, though. Even after regenerating a Camera Matched scene, rendering in vray produces an image as if the camera has zoomed in on the object.
                      I can't publish any image now, to show the problem, but I will try to do it later, so you can see what happens.
                      Take care,
                      Michael
                        broomstick
                        I had a little time to do a simple photomatch:
                        this is the photomatch scene:
                        http://www.3dita.it/plugins/vraytools/scena1.JPG
                        This is the recreated scene:
                        http://www.3dita.it/plugins/vraytools/scena2.JPG
                        This is what Vray comes up with:
                        http://www.3dita.it/plugins/vraytools/scena3.JPG
                        Any advice?
                          Is the V-Ray camera set to zoom?
                            broomstick
                            The zoom value of the Vray camera is set to 1,0
                            Do I have to look somewhere else?
                              penumbra
                              TT,
                              Thanks for the awesomeness, this one is a beauty. Put another beer on the map if in Baltimore.
                              I am experiencing some odd behavior, perhaps others are also. I have a simple studio scene set up. After running the plugin and applying aspect ratio I see the familiar safe frame bars on either side of the viewport just fine. If I orbit around the scene and then try to return the scene to its view point by hitting the scene tab, the bars disappear. The only way I can get them back is by clicking off the TT vray camera tools and then running the script again. not a big deal but wish it weren't so. Any thoughts?
                              Attached are some pics if it helps.
                              My office still runs version 1.48 on Windows 7 64 bit machine.
                              Omar
                              Desired Setup
                              Orbiting around
                              return to scene, bars gone
                                Not sure what it is. But I've had some issues occationally myself. Trouble is that SU doesn't expose everything. Might be that.
                                After you set the aspect ratio you need to Update the scene. (Right-click Scene Tab > Update)
                                  penumbra
                                  TT
                                  Thanks, sure enough that did the trick. Now i am embarrassed.
                                  O
                                    broomstick
                                    Thanks for taking the time to follow me through. Let's hope a new version of VfSU is on its way soon!
                                    • SupumanS Offline
                                      Supuman
                                      Thanks!!!very useful!!!
                                        sp33d1984
                                        http://t2.pixhost.org/thumbs/4648/16531774_error.jpg
                                          sezarx
                                          Hello Thomas,
                                          Thanks for the brilliant and very needed idea behind this plug-in!
                                          I'm having a difficulty installing it (using windows 7 64x , SU8 and vray 1.49)
                                          as it seems , all other plug-ins for sketchup have a folder that comes with the zip file , in the forum page here , I couldnt find anything more than the .rb file
                                          am I missing something?
                                          I'm really sure I copied the .rb file to the right location and still sketchup wont recognize any new plug-ins
                                          sincerely.
                                          Arch. Qais Tabib
                                            Note that the file you down load here is an RBZ files - not just RB. Right above the download in the red box there is a link to instructions to how you install RBZ files.
                                            • 11
                                            • 12
                                            • 8 / 12
