    [Plugin] V-Ray Tools
    238 Posts 80 Posters 301.7k Views 80 Watching
    • T
      tskoog20
      No. I can't open it in my downloads file .......I open .rb all the time when I'm installing plugins but I can't open .rbx for some reason?
        Install RBZ files using the Install Extension feature of SketchUp 8.
        General guide on installing plugins: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
          dtrarch
          TT
          I use Firefox not IE which is not installed.
          Will re-install and check.
          I'll bet that is the problem.
          Thx
          dtr
            What browser you use is not relevant. Internet Explorer always exist in some form in Windows.
            There is Internet Explorer the engine - webdialogs use it, .CHM help files use it, lots of applications use it in some form. It's an embedded version of IE.
            So, regardless of what web browser you use, keep Internet Explorer up to date as there is much more software that makes use of the IE engine.
              dtrarch
              TT
              I had removed/scrubbed IE off my system
              IE 10 now installed
              Error still persists.
              Is there a SU2Vray script that needs to be installed?
              Thank you for giving this your attention.
              dtr
                No, only thing that should be needed is this plugins and TT_Lib2. It's a very strange error you're getting. I've never seen it before.
                Maybe it's some setting on your computer?
                Can you fill out your system info in your profile, please?
                  dtrarch
                  dtr sys specs.jpgTT
                  System specs attached
                  SU 8 UPD PRO
                  I moved all the plugins not for this script to a temp hold folder.
                  Same error
                  Thanks again for checking this out.
                  Please do not make this a big project.
                  dtr
                    Could it be... there are some files in your VirtualStore?
                    This utility might help you check: http://sketchucation.com/forums/viewtopic.php?f=180&t=48399
                      dtrarch
                      TT
                      I have BU SSD for boot and apps.
                      Something on my current disk is just sideways.
                      The script runs perfectly on the BU drive.
                      Sorry to cause all the fuss.
                      Just a case of computer hell.
                      Thanks for all your good natured help πŸ‘ πŸ‘
                      Dave
                        Glad it works - somehow. :s
                        Did you check the VirtualStore?
                        • P
                          penumbra
                          Thomas
                          I get the attached error after install. any thoughts?
                            dtrarch
                            TT
                            Yes I did run the Virtual Store and error still there.
                            Could be a root kit or such but OK now.
                            Thx πŸ‘
                            dtr
                            • P
                              penumbra
                              TT
                              never mind about my issue. deleting the old TTLib and tantalizing the new one seem to get rid of the issue.
                              Omar
                                Milunice259
                                I have the same error like him. Anybody help!!
                                  Very little I can do without any further info.
                                  And as you can see in the previous post, penumbra solved it by uninstalling TT_Lib2 and then installing it again.
                                  • P
                                    penumbra
                                    of course rather than "tantalising" the old one I "uninstalled" the old one.
                                    • H
                                      harinama
                                      dude, i owe you a sixpack, if you're ever in Seattle...!
                                      Such a simple thing, to load or not load a plugin at SU startup, yet took hours of searching to find this tool. Works great, and solves a huge problem my labs are/were having with vray network licensing.
                                      Thankyou,
                                      Harinama
                                        πŸ˜„
                                        puts a beer mark on Seattle
                                        • broomstickB
                                          broomstick
                                          This new version is looking very good!
                                          I still have problems with camera match, though. Even after regenerating a Camera Matched scene, rendering in vray produces an image as if the camera has zoomed in on the object.
                                          I can't publish any image now, to show the problem, but I will try to do it later, so you can see what happens.
                                          Take care,
                                          Michael
                                          • broomstickB
                                            broomstick
                                            I had a little time to do a simple photomatch:
                                            this is the photomatch scene:
                                            http://www.3dita.it/plugins/vraytools/scena1.JPG
                                            This is the recreated scene:
                                            http://www.3dita.it/plugins/vraytools/scena2.JPG
                                            This is what Vray comes up with:
                                            http://www.3dita.it/plugins/vraytools/scena3.JPG
                                            Any advice?
                                            • 11
                                            • 12
                                            • 8 / 12
