    [Plugin] V-Ray Tools
    238 Posts 80 Posters 247.9k Views 80 Watching
    • N Offline
      nattawout
      thank you very much
      • N Offline
        nomeradona
        thanks thom, for the new release of vray i have to overwrite the old file right?
        visit my blog: http://www.nomeradona.blogspot.com
          you're talking about V-Ray Toys or V-Ray for Sketchup?
            troyhome
            I'm running 1.48.83 vfsu on my mac and vray toys doesn't work. Under Tools, there is a check by Load Vray on demand, but vfsu still loads. ?? any ideas? thanks! I used the great plug to prevent the extra time it takes SU to load. I miss that now.
            IOviz.com
            SU Pro 2024 PC
            • sadyoS Offline
              sadyo
              I'm running 1.48.89 vfsu, and it still working fine for me, I also experienced the same problem when first using this tool.
              You just have to click out the VRay Toolbar first, then restart the SketchUp
                hm.... maybe it's not finding the location of VfSU on OSX properly... any error messages in the Ruby Console?
                  troyhome
                  I'll try that- thanks!
                  update:
                  I opened SU, clicked on the Vray Toolbar and quick SU. I reopened SU and no change 😞
                  What did i miss?
                  update:
                  I thought it was solved, but the toolbar was just hiding...i thought it still took a long time to load SU...
                  IOviz.com
                  SU Pro 2024 PC
                    troyhome
                    ThomThom, no errors reported...
                    IOviz.com
                    SU Pro 2024 PC
                      You have the console open before you click Load V-Ray ?
                        troyhome
                        No, i just opened the Ruby Consol after SU started and didn't see anything.
                        There is permanently a check beside Load Vray, if that gives you any hints... I try to uncheck it and nothing happens.
                        IOviz.com
                        SU Pro 2024 PC
                          troyhome
                          There is permanently a check beside Load Vray on Demand, if that gives you any hints... I try to uncheck it and nothing happens.
                          IOviz.com
                          SU Pro 2024 PC
                            troyhome
                            okay- i am an idiot- i had forgotten to go into preferences and uncheck Vray in the extensions... well you know the rest. DUHHH... how many of these moments am i going to have this month??
                            IOviz.com
                            SU Pro 2024 PC
                              13 ... ?
                              πŸ˜‰
                              • sadyoS Offline
                                sadyo
                                this lovely plugin is not working on Sketchup8 ❓ ... waiting for an update πŸ˜›
                                  I'm using it with SU8...
                                  What exactly is not working for you? Error messages? No menus? VfSU won't start?
                                  • sadyoS Offline
                                    sadyo
                                    No error massages and menus is appear as usual, but it did not operate properly, i mean, nothing happen, there is no any VRay toys effect afterwards and VRay is still allready ON when i open the SU8 and not "on demand" like it should be πŸ˜‰
                                    1. i've put "VRayToys folder" and VRayToys.rb in SU8 plugin folder "\Program Files\Google\Google SketchUp 8\Plugins"
                                    2. i open the SU8, turn off the VRay toolbar and i quit SU8
                                    3. i open the SU8 again (this way is working when i'm still SU7) and then nothing happen...
                                    sorry if my explanation somewhat confusing πŸ˜„
                                    Start VRay on VRay toys not active
                                    VRay for sketchup and VRay tools still appear, even when the VRay toys alredy operate
                                      Did you just close the toolbar, or did you disable VfSU from Window > Preferences > Extensions ?
                                      You need to do the latter.
                                        setesur1
                                        Thank you very much. This looks very useful.
                                        This is my first message in this your great forum.
                                        I am spain. Perdon for my English.
                                        See you later
                                        • sadyoS Offline
                                          sadyo
                                          yes, I've done both ways...
                                          Finally, I tried to remove the VRayToys first, then put it back...
                                          Weird, VRayToys can work again like it should πŸ˜„
                                          But, when i try to Load VRay, it takes 15-20 minute to Appear 😒
                                          Is there something i done wrong? please help...
                                            15-20minutes???
                                            Does it do that if it loads normally?
                                            • 6
                                            • 11
                                            • 12
                                            • 4 / 12
