    Replace a frontdoor
    9 Posts 3 Posters 888 Views 3 Watching
    • P Offline
      PaulGJ
      How can I fit a door in a wall properly.
      I'am trying to change a frontdoor in a house, but if I replace the old door with a new one, it doesn't fit;
      because of the size
      because it's too far in front or too far at the back of the wall.
      Thank you in advance for your help
      Have a nice day
      Paul
        Hi Paul,
        You can always modify a door (component?). Could you attach the file so we can have a look?
        Also, I am moving this topic to the SketchUp discussions; LayOut is a separate program for which this forum is.
        • P Offline
          PaulGJ
          @gaieus said:
          Hi Paul,
          Thank you for your answer. I send you the file the door is at the right site of the house. It's the same problem with the large window next to it.
          Sorry, the forum doesn't except teh extension SKB. It says; "The extension skb is not allowed." What can I do now?
            Paul,
            The skb extension is the backup file extension of SketchUp. Attach the saved skp file instead (better than sending because others may have better ideas than just me)
            • plot-parisP Offline
              plot-paris
              you could of course open the skb file manually by opening SketchUp and then browsing to the file location (make sure to change the File type setting to 'All files'. otherwise you won't see the skb file)
                Yeah but he cannot attach it here (as it is not an allowed attachment type)
                  plot-paris
                  ah, I didn't know that 😳 (never tried)
                  • P Offline
                    PaulGJ
                    @gaieus said:
                    Paul,
                    I kept on trying, and trying, etc. at last it worked and I am happy because I found the solution myself and will never forget it πŸ˜„
                      Okay, glad to hear that (and indee the best way to learn and never forget again) but for the sake of others, could you share the olution? πŸ˜‰
