    Dashed lines in RpTools
    extensions
    1 Posts 1 Posters 646 Views 1 Watching
    • Al HartA
      Al Hart
      Al did you ever get the dashed lines to work in RpTools I have just tried and its not working, I do not want to keeping going on about things not working so sent this by PM.
      Richcat
      I don't mind if you mention things which aren't working - so I posted your question on the main forum. we added polylines to RpTools over a year ago - and no one has mentioned that the dashed and/or wide lines weren't working. So I assumed no one had any use for them.
      We are looking at the RpTools polyline stuff this week anyway, as part of our thoughts to add a wide, double line, polyline routine to use as a basis for walls.
      If you can wait, I'll take a look over the weekend and see why it isn't working.
      [Later]
      This is showing some promise. This is an example of a wide, triple line, with a dashed core line.
      Note how the "running" dash works its way around corners.
      Wide, dashed, polyline from RpTools
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
