    Bridging a wireless router...help
    3 Posts 2 Posters 396 Views 2 Watching
      Double Espresso
      Hey,
      I'm running into weak signal issues in my art studio and trying to add a second wireless router to serve as a bridge.
      Has anyone done this? And if so, how do you set it up? It's driving me nuts!
      Primary wireless router is a D-Link 615 and I am adding the same 615 model.
      Thx.
      • rodrigonotorR Offline
        rodrigonotor
        Double Espresso, first of all, Happy New Year.
        I think maybe the wireless signal is not strong enough to reach the second router, any possibilities to make the connection between the 2 wireless routers wired? I had the same problem, but i had a weak wireless signal so I had to put a cable between the routers.
        Sorry for the dumb question, but, you see the section 2, page 10 in the manual? "Connect to Another Router"
        Regards
        Edgar
        • Sketchando.net • www.arqcad.net •
          Double Espresso
          Thanks R, and All The Best To You.
          I should have mentioned that my house is totally hardwired with CATV and everything links to a central hub area. I went wireless about three years ago and all was good except the furthest point. The house is built on the side of a hill and I often joke - there's more steel and concrete than in the 'Golden Gate Bridge' holding it up. Anyway my issue is I use my MacBook most of the time in this area and the wireless signal has dead spots...BTW, tried a booster - not great.
          Cheers,
          DE
