    Curve-align textures?
    5 Posts 3 Posters 649 Views 3 Watching
    • P Offline
      Pg09
      Hello!
      This is my first question-post here.
      I was searching the forums but i didn't find anything similar to my problem...
      Can i align my texture like this: the object is a bracing for a lamp made of bent plywood and the grains should run along the curve not just in one direction...
      Is there a way to do that?
      Thank You!
        boofredlay
        Welcome!
        There are probably more ways than this but see attached for two methods.
        Just click on the scenes. Hope this helps.
        Arc Ply.skp
        • G Offline
          Yeah,
          Unfortunately textures don't "bend" by themselves (ah,how easy it would be to make arches with bricks!) so you have to position them on each segment.
          • P Offline
            Pg09
            Thank you guys!
            I think i will stick with the second method for now it seems to be more simple - especially when the arc is made up of plenty segments...
            Thanks again for the quick answer!
              boofredlay
              Happy to help.
