    Transparancy, groups and so on.
    6 Posts 3 Posters 577 Views 3 Watching
    • P
      per
      Hello. I am making windows, each window is a component, and I want to make the glass transparent but when I start to change the degree of transparency other things than the glass changes, like other grouops in other layers and so on. How do I isolate the change to that component, what am I doing wrong? WHow do correct? Regards mr Per Newbie.
      • GaieusG
        Hi Per, changes to transparency is applied per material so if you have any other object painted with that particular material, the changes will be applied model wise.
        • P
          per
          Ojojoj, I understand. I better change material then...πŸ˜„ Thanks.
          • GaieusG
            Or you can right click and "make unique"
            • P
              per
              aha. Good. Thanks! /Per
              • N
                neng83
                Gaieus was right, I have came across same problem before. I was create a surface and painted it with translucent material and realize that I need to divided them up and create a frame around it. Once I did all that I notice that when I orbit around those surface on the frame I create by drawing a line to divided the original face wasn't look solid. It took me a while to figure it out.
                Great work guys lot helpful information here.
                neng83
