    Off grid
    14 Posts 5 Posters 876 Views 5 Watching
      duxgga
      I'm trying to do the pot construction phases but i've come to a situation where moving the object around causes it wonder with no purpose or dirction, for it cannot go where the user had intended to.
      Any suggestions?
      tnx
        Hi Duga,
        What pot construction?
          sepo
          I am wondering what kind of "pot" is that....must be a strong one 😆
            C'mon...
            • Wo3DanW Offline
              Wo3Dan
              Duga,
              You can move geometry relative to...clicked point by typing <X,Y,Z> values followed by [Enter]
              Or to absolute locations by typing [X,Y,Z] followed by [Enter]
              (this is relative to the unchanged origin)
              Or use the arrow keys or [Shift] to constrain a move on one of the axes, a line or even a face.
              Or send the pot by airmail 😎
                sepo
                Sorry ... I just could not resist...no insult was meant.
                  duxgga
                  Wo3man - u understood me perfecly!
                  Tnx a million!
                    duxgga
                    Wo3Dan - tnx!
                    I've drawn this shape:
                    http://s1d3.turboimagehost.com/t/1097378_pott_shape.jpg
                    I'd like to know how to remove a piece to make room for the lead (top) and the same at the bottom..
                      duxgga
                      hi James, tnx..
                      http://s1d3.turboimagehost.com/t/1098991_mount_circle.jpg
                      by turning it i managed to center it and I request some guidance as to how does one cut it off..
                      • H Offline
                        Hazza
                        "Edit -> Intersect -> Intersect with model"
                        See all of my SketchUp models here.
                          duxgga
                          Tnx! Being a newbe I keep forgetting about it..
                            duxgga
                            This shape shows as if this is perfect center; well, it isn't.
                            http://s1d3.turboimagehost.com/t/1099234_modified_part.jpg
                            What can i do to correct??
                              Hu Duga,
                              With that particular shape you can also turn on hidden geometry (View menu) and delete the unnecessary parts.
                                duxgga
                                I'd like the shorter part to become the lead..
                                Now it is satisfactory:
                                http://s1d3.turboimagehost.com/t/1100285_removing_the_piece.jpg
                                The 1st question is how does one re-adjust the axes.
                                The 2nd question refers to the circle object. I'd like to move the indicated part.
                                Tnx
