    [Plugin] Selection Toys
    594 Posts 121 Posters 495.6k Views 121 Watching
      @tig said:
      If you click on just her 'gray' shirt then only one face will be selected, there are no edges in the selection to be considered for coplanar-ness...
      BUT if you double-click the shirt-face so that its edges also select... then some of those edges can be considered 'coplanar', because they border two same-plane-faces which also have the same 'gray' material...
      Select Coplanar in Selection Toys doesn't consider edges at all. Selecting one face is enough. See my previous reply - it's working on my machine and every other I've tried. This appear to be a local issue - which is why I suggested trying with just Selection Toys installed.
        @madpax said:
        Do the conditions of dependency mean that one cannot have both Quad Tools and the Selection Toys installed simultaneously? (Because of the different TT-Lib versions involved?)
        Cheers,
        Peter
        No - none of my plugins conflict with each other. TT_Lib is different from TT_Lib2 and they do not overlap.
        I was thinking there could be some other plugins you have installed - not one of mine - that might be conflicting.
        • F Offline
          fullyfledgeded
          thanks, is there any way to find out what the interfering plugins are?
            No easy way. 😞 Remove some, see if it works.
            What I would do:
            1. Make a backup of the Plugins folder. I'd rename it to something like "PluginsOrg"
            2. Copy just Selection Toys and TT_Lib over - see if it works then. If it does then we have confirmed there is a conflict.
            3. Copy half the plugin into the new plugins folder. Does it still work? Then copy the half of your remaining plugins. Continue until the issue appear.
            4. When the issue appear, start working backwards. Take the batch of plugins you added last and remove half of them until it works. Like that you can quickly narrow down to the offending plugin.
            Did any of that make sense?
            • cottyC Offline
              cotty
              Kind of bubble sort πŸ˜‰
              my SketchUp gallery
                caronte01
                ThomThom.
                Great plugin, thanks a lot!
                  caronte01
                  Hi ThomThom.
                  Thanks for your plugins!
                  IΒ΄m having issues with additional plugin folders and your plugin. I get the following message:
                  I tried putting ttlib2 in plugins, and in my additional plugin folder. Same error.
                  Santiago
                  Edit:
                  TTcleanup and TTsolidinspector work ok.
                    Selection Toys require TT_Lib version 1. It makes no use of version 2. Follow the link of requirements.
                      caronte01
                      My bad... didn't read the list of requirements at first. But, now it is asking for win32api. In installed it in the main plugin folder, and no go.... Does this plugin work on macos?
                      Santiago
                        Yes.
                        Have you checked that the file is there? Can you show a screenshot of the file in finder - including the path to the files.
                        • Dan RathbunD Offline
                          Dan Rathbun
                          @caronte01 said:
                          ... But, now it is asking for win32api. In installed it in the main plugin folder, and no go....
                          I changed my post for the Win32api.so library, to make the first line more obvious so you cannot misread it. I also copied the warning 2 more times, so it appears THREE (3) times:
                          Windows ONLY (Do NOT install on Mac!)
                          You should remove Win32API.so and win32ole.so from your Mac, please.
                          Do not throw away the brains that God gave you, just because some error message tells you to do things that you should know do not make sense. (This is how websites trick you into installing trojan malware on your computer.)
                          A Mac does NOT have a registry database (it uses plist files,) so should not be trying to load the registry.rb file, nor should it be trying to load either Win32API.so nor win32ole.so files.
                          If a plugin does try to do these things on a Mac, either the plugin is MS Windows only, or the plugin author did not determine the user platform correctly (or somehow, some plugin has changed the RUBY_PLATFORM global constant.)
                          Always get help from the plugin author first, rather than attempting "shot in the dark" solutions.
                          πŸ€“
                          I'm not here much anymore.
                            Dan Rathbun
                            http://sketchucation.com/forums/download/file.php?id=98319
                            (1) If you are on a Mac, why are you prefixing paths with a drive letter (such as πŸ˜„,) this is only done on MS Windows.
                            (2) Are you responsible for putting the dashes " %(#804040)[-]" into the library directory name ? (ie: " %(#804040)[-Libreria-]")
                            This may not be a wise idea.)
                            (3) Try to limit any characters in directory names to the UTF-8 character set. (Simple ASCII characters are even better.)
                              driven
                              @dan,
                              it looks to me that he has two systems with a shared dropbox for his plugins [some very out of date], the win fileis already in TT's lib, but additional folders reports it as missing even if it's there.
                              I think it loads first to monitor the other rubies,
                              this runs on a mac fine, if you have the Lib...
                              john
                                Dan Rathbun
                                @driven said:
                                @dan,
                                Sounds like trouble to me.
                                  @dan rathbun said:
                                  @driven said:
                                  @dan,
                                  I do that same - one Dropbox folder, three windows machines, one OSX. No problem.
                                    Limit? What characters are not covered by Unicode?
                                      Isn't that what has been done here..? I think you've jumped the gun on a few things here.
                                        Dan Rathbun
                                        Sorry.. I will bow out of this. 😳
                                          Would you by any chance happen to have Organizer installed? That could explain why these files are being loaded.
                                          Selection Toys uses only a very tiny subset of TT_Lib - the rest of TT_Lib isn't even loaded. the .so file should be inert as there is no other plugin using TT_Lib and certainly not the functionality of the .so.
                                          Organizer does do some weird things such as load going into subfolders and load the files there, which causes problems as files might be loaded in the wrong order.
                                          But I still don't get why the .so and registry files are being loaded as the code calling it is wrapped in guards that should prevent them from loaded directly. So it almost seems that something is bypassing this is loading the files directly.
                                          I'm not quite sure how Fredo's Additional Folders plugin work though - which you appear to be using.
                                            No worries. Enjoy the jolly times ahead! πŸ˜„
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 29
                                            • 30
                                            • 23 / 30
